Originally Posted by trails
(Post 6702667)
paul's 18g looks very similar to andy's :)
have you had the car dynoed...be interesting to see how similar they are as i'll be keeping my standard ported headers and mines a phase two with a standard TEK3'd ECU...who mapped your car? sorry loads of q's :D Mapping was done by Paul Blamire of Zen Performance. I've had it on current setup for about 14 months and approx 15k miles. Car in total has done approx 84k |
Originally Posted by billsandhu
(Post 6703272)
Had the car dynoed at powerstation. They only gave it one run but it made 333bhp and around 292lbft torque. It didnt achieve full boost on rollers like it does on the road.
Mapping was done by Paul Blamire of Zen Performance. I've had it on current setup for about 14 months and approx 15k miles. Car in total has done approx 84k what rpm does it make full boost at and what are you peaking at? i'd have expected to see much higher figures with the spec you are running, did you speak to paul after the rr session? |
A lot of the cars on the day seemed to be running lower than expected torque figures. On the rollers it only peaked to 1.4bar boost, but out on the road it peaks at 1.5bar and reaches full boost by 3.5k rpm.
I wasnt too concerned with the rolling road figures. Maybe it would have produced better if they gave it a 2nd run. On the day it actually made more power and torque than a car running a 20g turbo, so on that comparison it done well. It could do with an electronic boost controller to maybe hold a bit more boost at the top end, which is my next planned mod. |
(Post 6704634)
I wasnt too concerned with the rolling road figures. Maybe it would have produced better if they gave it a 2nd run. On the day it actually made more power and torque than a car running a 20g turbo, so on that comparison it done well. It could do with an electronic boost controller to maybe hold a bit more boost at the top end, which is my next planned mod. Power at Flywheel (BHP) : 215 Power to Weight Ratio (BHP Per Ton) : 172.01 0 - 60 (Secs) : 5.74 0 - 100 (Secs) : 16.34 60 - 100 (Secs) : 10.59 Drag Strip Quarter Mile (Secs) : 14.13 Drag Strip Terminal Speed (MPH) : 97.21 Power at Flywheel (BHP) : 280 Power to Weight Ratio (BHP Per Ton) : 224.01 0 - 60 (Secs) : 4.52 0 - 100 (Secs) : 12.12 60 - 100 (Secs) : 7.60 Drag Strip Quarter Mile (Secs) : 12.84 Drag Strip Terminal Speed (MPH) : 107.94 Power at Flywheel (BHP) : 360 Weight without Driver (KG) : 1270 Power to Weight Ratio (BHP Per Ton) : 288.02 0 - 60 (Secs) : 3.69 0 - 100 (Secs) : 9.51 60 - 100 (Secs) : 5.82 Drag Strip Quarter Mile (Secs) : 11.93 Drag Strip Terminal Speed (MPH) : 117.72 |
(Post 6705560)
very strange, well as the 18g is rated to over 370 i used the performance calculator from here; Car Stats - Calculator to work out some figures based on 215bhp (standard), 280bhp (de-cat and TEK3) and finally 360bhp (18g and appropriate ancilleries). All figures based on kerb weight of 1270kg as specified in SIDC faq.
Power at Flywheel (BHP) : 215 Power to Weight Ratio (BHP Per Ton) : 172.01 0 - 60 (Secs) : 5.74 0 - 100 (Secs) : 16.34 60 - 100 (Secs) : 10.59 Drag Strip Quarter Mile (Secs) : 14.13 Drag Strip Terminal Speed (MPH) : 97.21 Power at Flywheel (BHP) : 280 Power to Weight Ratio (BHP Per Ton) : 224.01 0 - 60 (Secs) : 4.52 0 - 100 (Secs) : 12.12 60 - 100 (Secs) : 7.60 Drag Strip Quarter Mile (Secs) : 12.84 Drag Strip Terminal Speed (MPH) : 107.94 Power at Flywheel (BHP) : 360 Weight without Driver (KG) : 1270 Power to Weight Ratio (BHP Per Ton) : 288.02 0 - 60 (Secs) : 3.69 0 - 100 (Secs) : 9.51 60 - 100 (Secs) : 5.82 Drag Strip Quarter Mile (Secs) : 11.93 Drag Strip Terminal Speed (MPH) : 117.72 Power at Flywheel (BHP) : 330 Weight without Driver (KG) : 1270 Power to Weight Ratio (BHP Per Ton) : 264.01 0 - 60 (Secs) : 3.95 0 - 100 (Secs) : 10.30 60 - 100 (Secs) : 6.35 Quarter Mile (Secs) : 12.62 Terminal Speed (MPH) : 110.67 Drag Strip Quarter Mile (Secs) : 12.22 Drag Strip Terminal Speed (MPH) : 114.39 |
Originally Posted by Mangel
(Post 6705804)
Mine, reckon I'll need a new clutch!!
Hmmm right quick bit of research and
Power at Flywheel (BHP) : 330 Weight without Driver (KG) : 1435 Power to Weight Ratio (BHP Per Ton) : 233.66 0 - 60 (Secs) : 5.05 0 - 100 (Secs) : 11.27 60 - 100 (Secs) : 6.22 Quarter Mile (Secs) : 13.32 Terminal Speed (MPH) : 108.71 Drag Strip Quarter Mile (Secs) : 13.12 Drag Strip Terminal Speed (MPH) : 110.66 doesn't help with the clutch though!!!! |
that calc seems more accurate on the other 1/4 mile time it comes up with. not the drag one. that seems a bit optimistic to me.
(Post 6706004)
Originally Posted by wrxginge
(Post 6706041)
(Post 6706223)
probably makes it even worse being a lardy new age and all ;):)
(Post 6706223)
:lol: :lol: :lol: :lol: |
Its exactly what it says on the tin - Classic
(Post 6706223)
* Having a high quality or standard against which other things are judged * A creation of the highest excellence * Adhering to established standards and principles * Having all the characteristics or qualities that you expect * Of enduring interest, quality, or style * Of Definitive Character * Something noteworthy of its kind and worth remembering :D :D :D |
Originally Posted by *smiles*
(Post 6707321)
clas sic - [klas-ik] –adjective
(Post 6708006)
pmsl, nice cut and paste steve :D
* To lace heavily with extra material Lard Arse * Something that is fat, bloated and overweight :lol1: :lol1: :lol1: |
(Post 6708035)
Lard Arse
Originally Posted by Granby
(Post 6708049)
So your not talking about your wallet at the moment then :p
broke - lacking funds; "`skint' is a British slang term" bust, skint, stone-broke, stony-broke |
(Post 6708049)
http://i16.photobucket.com/albums/b1...s-esc/PO88.jpg |
My 1999 wagon, standard apart from indicators and rear prodrive box - love it! needs a good handwash, I'll post better ones later only had it 2 days! :luxhello:
http://img340.imageshack.us/img340/3074/imp2000af8.jpg |
Welcome to Wagoneering :luxhello: :luxhello:
1999 was an especially good Vintage for the Wagons :D
Originally Posted by ollyit
(Post 6708715)
(Post 6708715)
http://img340.imageshack.us/img340/3074/imp2000af8.jpg ignore smiles he's got it all wrong you want a MY00 :D |
(Post 6708811)
a nice green one :)
ignore smiles he's got it all wrong you want a MY00 :D 1999 Last of the Sti v5/6 Wagons :norty: |
(Post 6708831)
ha ha, have I started something here?! I LOVE the look of the wagon! was i right in thinking "x" reg was the last of the classic wagons?
also... sorry bout all the questions, has it got roughley 215bhp? more or less do you think :wonder: |
(Post 6708873)
MY99=sti5 and MY00=sti6 ;)
Wagon for Smiles |
Dont forget to say hello on this thread also
https://www.scoobynet.com/scoobynet-...sign-here.html And Trails one on SIDC - Wagoners Role call |
(Post 6708881)
also... sorry bout all the questions, has it got roughly 215bhp? more or less do you think :wonder: have a butchers here as it will answer all your spec and model questions; Subaru Impreza FAQ |
(Post 6708882)
I'll grab my flight suit :iamwithst
Wagon for Smiles looking forward to catching up with everyone in person again :) |
Type WA Lives
First Combat Mission with new JDM STi 9 Bottom end (mahle pistons/acl bearings etc)
:D :D :D :D Need to put some miles on it to get it run in, done 500 so far. We are off to SurreyScoobies meet Sunday, so say hello if your there :thumb: http://i16.photobucket.com/albums/b1...c/DSCF3781.jpg http://i16.photobucket.com/albums/b1...c/DSCF3782.jpg http://i16.photobucket.com/albums/b1...c/DSCF3783.jpg http://i16.photobucket.com/albums/b1...c/DSCF3779.jpg http://i16.photobucket.com/albums/b1...c/DSCF3788.jpg http://i16.photobucket.com/albums/b1...c/DSCF3785.jpg http://i16.photobucket.com/albums/b1...c/DSCF3784.jpg |
Spec and more pics to follow at weekend
