Renault Clio ECU reset
Hi Guys,
Does anyone know how to reset the ECU on a Renault Clio? Its on a 51 plate if this helps. thanks. |
what are you wanting to reset if for mate?
www.cliosport.net there are plenty of info guru's on there, and stickys on howto's......
Disconnect the battery overnight
pop the bonnet on the rear of the engine you will find the processor unplug it turn the ignition on then off and plug it back in. this did the trick on my m8s motor
