Is Power Steering Fluid Flammable?
If spilt/leaked on manifold or exhaust
Cheers |
would have thought so, it is oil type fluid :wonder:
Ive got a pretty bad leak from my power steering reservoir which is getting blown back onto the turbo/exhaust,doesn't smell too nice.
It hasn't caught fire yet but im not going to leave it like this for long just incase ! |
YES it burns well.....
yep highly flammable..
I have the same problem as 340BHP-WRX, it is pi**ing everywhere. :mad:
Not Good then Gary!:(
It does! From experience, first time driving a rally car to the start of the rally, there must have been a small spill on exhaust manifold, no damage.
Second time with flames in a legacy on the way to work, had some water in the car and put it out. |
double post.......
Originally Posted by RMA26
(Post 6636974)
No, Power Steering Fluid, like Brake Fluid is inflammable.
Petrol is flammable. Water is non-flammable. Semantics I know but there is a difference. This is how it was explained to me be a chemist at an Oil Refinery (who, let's face it should know;)); Inflammable means that a substance will ignite at atmospheric pressure when heat only is applied, no ignition source is needed. Flammable means that a substance needs either an ignition source, a pressure increase, or both. Non-Flammable means that to all intents and purposes a substance wont burn even if you apply heat, pressure and an ignition source. |
Originally Posted by CrisPDuk
(Post 6637877)
Petrol is flammable. Water is non-flammable. Semantics I know but there is a difference. This is how it was explained to me be a chemist at an Oil Refinery (who, let's face it should know;)); Inflammable means that a substance will ignite at atmospheric pressure when heat only is applied, no ignition source is needed. Flammable means that a substance needs either an ignition source, a pressure increase, or both. Non-Flammable means that to all intents and purposes a substance wont burn even if you apply heat, pressure and an ignition source. Simon |
at a guess, I would say flammable
