SUBARU IN DASH SINGLE DIN SAT NAV CD RADIO
THIS ITEM HAS NOW BEEN SOLD
VDO DAYTON MODEL MS4150 RDS BRANDED AS SUBARU. WORKS WITH TMC CODES TO AVOID ROAD CONGESTION. TOO MANY FEATURES TO MENTION HERE IS A LINK TO VIEW THE SPEC AT BOTTOM. PLEASE NOTE THERE IS NO Q-IC WHICH IS A SUBSCIPTION BASED MAP SYSTEM, THIS USES VDO DAYTON MAP CDS I WILL THROW ON IN WITH THE SET. YOU WILL SEE THERE MS4150 RDS In Dash Navigation Unit £599.99 Fitted Price May Vary On Certain Cars £699.99 Pre Loaded With UK Map I WILL LET IT GO FOR £195 WITH FULL INSTRUCTIONS AND DISC BUT ALL SETUP IS DONE FOR A MY05 WRX/STI. INCLUDES THE HARNESS ADAPTOR AND MOUNTING BRACKET FOR GPS ARIEL OBVIOUSLY YOU WILL NEED A SINGLE DIN SOLUTION FOR YOUR UK CAR. http://i6.photobucket.com/albums/y20...4/PICT1784.jpg http://i6.photobucket.com/albums/y20...4/PICT1780.jpg I CAN HELP YOU INSTALL IT IF ITS LOCAL TO NEWPORT. TEL 07771802132 V D O Dayton Offer A Full Range Of In-Car Navigation Systems |
I have just priced up the SUBARU fitting kit to convert a double din dash to the same spec as mine, it includes the complete new single din facia panel and the radio mount. £70.24 + Vat.
The SAT Nav is priced at £595.00 check with your dealer, part numbers are Nav Radio H001ESA010 Conversion and installation kit H0010FE000 The radio fits from MY05 and also the latest 2.5 version too. |
bttt
