Size of speakers for '07 Impreza???
Hey fellow Subaruers... can someone let me know the size of the speakers that come stock in the '07 Impreza, so i can change them?
can anyone enlighten on this thread as i want to do the same cheers peps!!!!
the speaker itself it 5.5" in diameter and approx 51mm deep :thumb:
just sat one on my desk and measured it :D |
thats great thanks any ideas on the back speakers?:notworthy
fronts-you will get 6 1/2 inch speakers into the holes,but make sure spacer rings/corsa pockets are used,otherwise the speaker will foul the window mechanism
rears-4" speakers is all it will take,unless you fancy modding the doors marcus |
i thought the backs are 5.25 not 4" was told this by and audio shop so who is right????????:wonder:
Originally Posted by postie90
(Post 7264819)
Look at the sticky thread at the top of the page, has all the sizes in there MY07 is the same as MY01-06.... the doors didn't change ;)
Tony. PS the newage rear speakers are not in the parcel shelf, unlike the ooooold classic. |
hi
iv just got a 55plate newer shape wagon r sport are the spekers the same size in the back or are thay a difrent size? the front are 6 1/5" and the back 4" is this right lol also i would be looking for some alpine speakers dose any one no of any good ones? thanks |
that is correct buddy
6 1/2 in the front,4 in the rear doors for alpine speakers get over on ebay"stores" some bargains to be had,whilst changing the front door speakers,make sure you fit a nice set of components with cross-overs and new tweeters,it improves it no end infinitys can be had for as little as £38 for 61/2 components on ebay marcus |
(Post 7264819)
Try and fit some 5.25 speakers in your rear door buddy,and then all will become clear :wonder: regards marcus |
iv just got some back 4" alpine components will thay just fit strate in oe will i need to make something.
also dose any one know hows best to remove the door cards front and back? thanks agen |
Originally Posted by Keith1982
(Post 7298493)
also dose any one know hows best to remove the door cards front and back? thanks agen It's easier to read your text if you stopped using txt language!:nono: |
sorry ill try and stop
I have 5 1/4'' in the rear of my 07....an absolute doddle to fit and without having to drill anything either using the leftover flat plate from the front Corsa adaptor kit:)
Elmer you have mail :D
hope this helps 2005 Subaru WRX Wagon Speaker Installation
