Gear box oil
Just a quick question for u guys who have used various diffrent oils.
Which is the best? Nicky |
I find castrol syntrax/driveline best.
has any1 used silkoline i think its called, if they have is this anygood my local performance centre sell it.
If any of u are from Northeast ul know Revolution and if u dont look them up on the net great place. |
castrol syntrax
Originally Posted by Nickyv4
(Post 7498642)
From experience it could be an expensive mistake to use full-synthetic fluid in the Impreza box. It works for some but there's also quite a few who have had issues with the synchro performance. It's wiser to stay with a good semi-syn. fluid such as Castrol Driveline (Syntrax)
By all means use a full-syn. in the rear diff. JohnD |
redline or royal purple gear oil
Is there only 1 syntrax driveline is it the universil 1 thats 75-90. how many litres will i need cos the only place i can find it is Halfords and they only sell it in 1 litres.
(Post 7509661)
There was a group buy from Opie oils on this a couple of weeks ago. Maybe still worth giving them a call! JohnD |
Depends on the car,use, and the diffs in your impreza.
Castrol Syntrax 75/90 for GT/WRX Castrol SAF X or SAF XJ 75/140 for DCCD/LSD cars Redline Heavy Shockproof and Lightweight Shockproof is ONLY good on dog gearboxes, and your syncromesh standard impreza box dont like it at ALL. Stick to "ordinary" Redline Syntetic, and not to shockproof series. For impreza dog gearboxes: Shockproof light/heavy is a good choice. 5litres is more than enough: 4L on the gearbox and 1L for the rear diff. If your impreza has a gearbox oil cooler(spec c), you will need more oil. |
Originally Posted by JohnD
(Post 7499639)
yup,i had castrol syntrax in my box, just changed it,done 11k,and used valvoline dualblend synthetic blend,crunches from 5th to 4th now ASWELL AS FROM 1ST TO 2ND,it did the 1st to 2nd so thats not new but no wi have 2 gear crunches,back to castrol syntrax/driveline its called now.
