How do you glue your teeth back in?
I have two crowns, well - not crowns as such - more false teeth which have a 'stud' on them and they sit inside the tooth root.
One of them came out, it's a molar, whilst in Cornwall last year ..... I bought some DenTek cement and stuck it back in. Later that same holiday a wave knocked my surfboard back into my mouth and loosened my front false tooth .... it didn't come out. That was last July and I have glued the molar back in on one more occassion, it is no worry really as the natural way it sits is to be pushed back into its socket. The front tooth is another issue alltogether, it is subject to sideways forces ..... it needs securing much stronger. Anyway, this front tooth popped out half an hour ago - luckily the whole stud came out too. I filled the root with DenTek and smeared some on the stud of the false tooth, pushed it back in and I am handsome again :D I can't help but think that some glue would be better than cement? There was someone on the TV just before Xmas who had 'SuperGlued' their teeth back in ..... seemed to be doing a good job too! Do you lot carry out DIY Dentistry? I'm an engineer by trade and most of it is simple Engineering ..... I wish Engineers got paid half as much as Dentists mind you! :D Any recommendations for clinically safe strong glue? It's cheaper for me to buy the glue and glue the teeth back every 6 months than pay one very expensive visit to the dentist. Any chemists out there? |
Originally Posted by fivealive
(Post 7620322)
Stop winging Pete and go see a dentist. Most glues you will buy are toxic if they enter the blood stream. |
IIRC didnt someone die using superglue on dentures
Gripfill?
Ad says: Gives excellent adhesion and bonding strength to most solid materials. Bonds plasterboard, teeth, skirting boards, Space shuttle thermal tiles, electrical conduit, non moving body parts, stone, ferrous and non-ferrous metals. Should do the job. |
How about no more nails!! :lol1:
Seriously from what I remember a proper dental cement will bond with the dentine as well as forming a seal. Its when that seal goes that the crown falls out. I would think that a temporary cement is slightly different formula to one that your dentist will have as it is meant as a temporary measure to give you your handsome smile back until you can get an appointment and the dentist can remove it more easily to check that all is ok before cementing back in. But you know all this Pete - Al has been through it many times with you. Tut tut. Sara |
just sounds like your trawling for attention imo :rolleyes:
Originally Posted by dpb
(Post 7620605)
Originally Posted by Sonic'
(Post 7620528)
Super glue was invented for glueing flesh so I doubt it :) |
Get yourself to the Dentist, you tight bugger :lol1:
Pete, this afternoon http://img115.imageshack.us/img115/6190/teeth3he.jpg |
I use Araldite on my falsies :thumb:
Originally Posted by scoobychick
(Post 7620785)
Originally Posted by B-B
(Post 7620703)
No dpb he really has got a loose crown at the front - it looks dreadful. He wont put his hand in his pocket to get it sorted :lol1:
Looking at the root, it looks like it may be split and a Dentist will see ££££££ signs floating around my head :lol1: When I put the tooth back in it went right back and lined up with the others - but, with the cement it is raised again but not as bad as B-B had to witness ;) Really, it is simple Engineering .... I begrudge paying loads for a simple glue job! |
Originally Posted by 84of300
(Post 7620795)
Is that so they don't fall out of your bra :D
(Post 7620809)
I don't keep my teeth in my bra :wonder:
Falsies are teeth, ahhhhh ;) |
I did find this
As a dentist in the US, superglue will kill the nerve in your tooth over time, causing a root canal to be needed. If the tooth already has a root canal, it may not cause nerve damage to the tooth, but if it runs onto the gums, it can damage the blood supply to the gum tissue. The gums are a mucosal tissue, much different than putting on your skin. It has more nerves and blood supply. Also, most likely you would be sealing up tooth decay under the crown, causing it to eat away at the tooth, causing more tooth structure damage. Crowns usually come off because a cavity was under the crown. Here in the US, temporary dental cement is available in most drugstores, and it is the same as dentists use. |
This is me before my DIY Dentistry:-
http://www.moodyterrace.com/images/B...ng%20teeth.JPG and this is what a few minutes with the dremel and a tube of SuperGlue did:- http://www.dentistryonking.com/files/4-1035-thumb.jpg Handsome as ever I was :D |
Originally Posted by [Davey]
(Post 7620729)
(Post 7620807)
Hey, guess what? When it finally let go it came out with the post too woohoo!! You know I was worried that it may have snapped like last time.
Looking at the root, it looks like it may be split and a Dentist will see ££££££ signs floating around my head :lol1: When I put the tooth back in it went right back and lined up with the others - but, with the cement it is raised again but not as bad as B-B had to witness ;) Really, it is simple Engineering .... I begrudge paying loads for a simple glue job! Does this mean you are back on the snogging again if its refixed??? :lol1: |
SuperGlue should be OK ... it was designed for bonding wounds together in the battlefield.
(Post 7620830)
Not being facetious - just asking. What makes you think it is split?
Does this mean you are back on the snogging again if its refixed??? :lol1: Snogging? I doubt if the glue is THAT strong!! :lol1: |
(Post 7620729)
Not exacty, super glue and medical glue are slightly different. The medical version is not exothermic (gets hot when setting) where as the stuff you'll by for DIY is. Both however have Cyanoacrylate as the base, from there the similarity ends. |
(Post 7620824)
I just read that someone did die from using superglue on their teeth, but they accidently superglued them together and starved to death, somewhere in Peru apparently :)
(Post 7620846)
I know I shouldn't laugh but :lol1:
(Post 7620822)
(Post 7620835)
There looked like a crack/indentation when I looked up into the root.
Had the gum grown over the root surface at all before you tried to cement it back in? If it has split in a big way you would probably be able to see it move when the crown was out.
Sonic - its not necessarily decay that causes crowns to fall out. If the seal of the cement is broken then it will fail...simple. That can be caused by a lever type effect for instance on a front tooth - or as possibly the case in Pete's the root may be split. |
(Post 7620857)
Must be one hell of a hole for you to be able to see up into the root :D
(Post 7620872)
I was actually quite surprised at how clear the root is - it is quite a big hole - the dentist who did the job said that I would not snap the post (his earlier post was thin and did snap) ..... he was absolutely spot-on.
(Post 7620872)
Off to watch Khan |
