if you use a glue to sort your teeth this is an easy way to kill yourself. dont use a glue. go to a dentist. if the glue enters the root/gum it ill go very fast upwards to your brain.
My dad has superglued his teeth back in about four times now. Told a guy at work just put the glue on the tooth and dry your gum. Hold it in place till it dries and hey presto.
The results, the guy superglued his finger to his bottom lip!! |
Originally Posted by fraser87uk
(Post 7621063)
You are pushing your luck Pete. Superglue has cyanide as an ingredient too!
Les |
Well, today I have discovered that I cannot eat!! :(
I have glued the tooth back and it is hitting the lower front teeth before the molars come together ........ :cry: But, I could do with losing some weight - liquid diet here I come! :( |
Originally Posted by pslewis
(Post 7622328)
I have glued the tooth back and it is hitting the lower front teeth before the molars come together ........ :cry: But, I could do with losing some weight - liquid diet here I come! :( Get yourself off tomorrow and get it fixed professionally :thumb: |
Originally Posted by 84of300
(Post 7622967)
Pete, the Reg Prescott of Dentistry :lol1:
Get yourself off tomorrow and get it fixed professionally :thumb: B-B |
Originally Posted by Leslie
(Post 7621455)
Les Indeed - Cyanoacrylate I say go for it Pete, you may yet make it to the Darwin Awards!!!! :D |
Well, been to see the brand new NHS Dentist in our town ..... he had a cancellation so fitted me in.
He pulled, he tugged, he huffed and he puffed - the damned crown wouldn't come out (and there's me thinking a bit of toffee would pull it!) ... he saw some bad infection around the tooth in the gum but non in the root area after an X-Ray. As he couldn't pull it out he has ground it down level with the other teeth so I'm at least really handsome again ..... but it still feels like the 'bite' is wrong? Cost? a very reasonable £15:90 ... can't say fairer than that :thumb: £6:85 for the Penicillin though! :( |
I used to use poligrip :)
but now they stay in all by themselves :) Mart |
(Post 7624967)
He pulled, he tugged, he huffed and he puffed - the damned crown wouldn't come out (and there's me thinking a bit of toffee would pull it!) ... he saw some bad infection around the tooth in the gum but non in the root area after an X-Ray. As he couldn't pull it out he has ground it down level with the other teeth so I'm at least really handsome again ..... but it still feels like the 'bite' is wrong? Cost? a very reasonable £15:90 ... can't say fairer than that :thumb: £6:85 for the Penicillin though! :( Oh and guarantee to pull a crown, Airwaves, Black Mint. Pulled my crown 3 times so far :lol1: |
Went to be early, slept reasonable ..... all my gum is nagging this morning - day off work and a lie in bed taking penicillin ....... everyone - awwwwwww!! ;)
I would really like to know exactly what he said to you about your botched home repair job though!
Les :) |
(Post 7627401)
Les :) He wouldn't be able to say anything, he was probably too busy laughing :D |
(Post 7627914)
He's gone very quiet-do you type with your teeth Pete? Les :D |
