MOT Failure - chip on windscreen.
I have an MOT due on 28th. Screen has a chip in it, only about 3-4mm accross. Is that a failure? - its right in my line of vision too.
I think its a fail if there is any crack over 10mm accross in the line of vision, but might be wrong. If its going to fail I will get a new screen on before it goes in. Cheers. |
If it will fit into a 10mm diameter you will pass - but would expect an advisory.
See if it can be repaired? Some insurance companies will sort it out for nothing.
just get a new one anyway, only be £50 on the insurance and you wont loose any no cliams, and you may find they can repaire it on the insurance which will cost you nothing
If the chip can be repaired, it won't cost anything.
This mob are on the radio all the time telling you how it wont cost a penny to repair,(as long as you have fully comp insurance).
AUTOGLASS® UK: 24/7 mobile windscreen chip repair & glass replacement |
Originally Posted by pslewis
(Post 7647630)
If you pass your garage just drop in and have them check it...a good garage won't mind :)
My Ibiza passed with two ~5mm chips, and didn't get an advisory either. This is in NI where test center's are government run, and thus generally strict.
Last week Autoglass charged me a £10 compulsory excess that Direct Line are now apparently wanting for a windscreen repair.
I can understand why as it appears that in every car park in the land someone is offering free windscreen repair. Someone somewhere has to be paying for it, and it wasn't that long ago it couldn't be done. So the insurance companies must be paying out a fortune! |
Originally Posted by Chrisgr31
(Post 7648667)
