Head gasket blown - Thermaseal type quick fix?
Hi All,
Head gasket is likly got a slight blow - oil to water - small amount of creamy cr@p in the tank, nothing to bad. Replacing the rad tomorrow which is the likely cause of the problem. Are any od the pour-in type remedies any good? My main issue is that the blow will push whatever sealant i put in away as the oil is under pressure and blowing into the water if you see what i mean The car in question is my old Pug 406 TD sh*tter worth not a lot so do not want to spend good money after bad. The car needs to last for 12 months or so and around 12k miles and i will likely scrap it. some of the prods RxAuto Head Gasket Repair | Blown Head Gasket | Call 1-866-780-9042 Bar's Leaks Head Gasket Repair Steel Seal- RETAIL CUSTOMERS Any reccomendations or any to steer away from? I know i could poist in OM but is it a general question about this stuff rather than car specific if you see what i mean. |
Why would a duff rad cause a gasket problem??
I had similar probs with a 205 tdi and we tried various fixes. Main thing was to check water level daily and top up. It used gallons of water but still ran well :) My main concern was no water and consequent seizure. In the end I got a new head gasket but an expensive job with a turbo bolted on in labour terms. I'd say try the fixes first and it might be OK. If not - well pay up or scrap!! david PS. Isn't that a USA number at top of list :rolleyes: |
peugeot TD engines are a nightmare for head gaskets,dont ever let it overheat,carry plenty of water wherever you go.They warp cylinder heads very very quickly
Got a similar problem with the Toyota Previa, and was looking around at some products
one of the cylinders is letting water in, so is misfiring on start, and quite a bit of smoke (unless I drive it every day) but runs ok when running and warm :D only paid 950 for it, and its 500 for head gasket replacement, I know they mentioned a product over on the Shogun forums that is supposed to be pretty good but the name eludes me for the moment (it is from the states too I believe) Mine is losing about 3 pints of water for 5-10 mile trips from cold |
Could always try putting a touch more torque on the head bolts* :D
Tighten in a cris-cross patten. Like you should do with wheel nuts. *will not be held responsible if a bolt shears off :razz: Pug 1.9 diesels are common for it. Lack of coolant changes is the main curlprit - old acidic coolant eats the gasket. Simple job, somewhat labour intensive as its typically French with everything being positioned in a cock-eyed manner. Not as bad as doing the same engine in a Pug Expert van....bad back anyone? :mad: |
What about my Previa SM, bleddy engine is under the drivers seat as its midmount
Book time is 8 hours to change the head gasket on it (its a 2.4 petrol) |
I have always found that once a head gasket gets a small leak, it will only get bigger and have never found a way to plug it successfully yet. Too much pressure to keep in.
Les |
Originally Posted by Sonic'
(Post 7971638)
Book time is 8 hours to change the head gasket on it (its a 2.4 petrol) Never worked on one. Done a few Bedford/Isuzu Midis and LDV/Nissan cubs/vannetes, and despite being mid-engined, its dooable as the access hatch is big enough or the entire seat box can be removed. Just googled and found pic of previa access - oh dear :D looks like engine has to be dropped out from underneath, or dropped down onto axle stands/ blocks to get enough access to it. Something tells me Toyota didn't quite think the design through very well with teh Previa :eek: Oh well, Espace is no better, and they go wrong a lot more often ;) |
Cheers Ali :)
I did have the drivers seat out and access panel (ttok bleddy ages) so I could change the spark plugs thinking it was those originally Yes not the best thought out layout, but then I have no idea if they changed the access on the newer generation models (mine is the 1st generation 1996 model) |
