Hi Tim,
according to this paper (found it in an us scooby forum) the Suretrac diff is similar to Torsen (Helical) and open diff. https://cimg6.ibsrv.net/gimg/www.sco...fc09a8d05d.jpg Greets Max |
Hi Max
Fair enough, if it has that diff then you should be fine with the Gear 300. Cheers Tim |
Hi Tim,
thank you sooo much :luxhello: Greets Max |
Originally Posted by Dignitas
(Post 11900234)
Hi, my Name is Max,
I'm from Germany and last week I bought an stock WRX STI WR1 with already 90k miles on it. Since I don't know how long the gearbox and rear diff have not been serviced I'd like to change the oil in both of them. Since my car is a WR1 it has according to the internet Suratrac front and rear LSD's and also DCCD. The gearbox seems to be in a healthy condition, no grinding noises when driving the car harsh. The only problem I have is that with low temperature (below 10°C) getting the first gear (and some times the second gear) in is for the first miles not so easy. After doing 3 hours of research I found out that the Motul Gear 300 should be put in the gearbox and the rear diff, but maybe I'm wrong here. So my question is which oil should I get for the gearbox and the rear diff? Cheers Max |
think its the motul 90 i put in mine!
Originally Posted by silver sonic
(Post 11901940)
hi MAX What number you bought, nice to know which ones go abroad!
(Post 11902485)
Mine is 103 :thumb:
Hi Tim,
Need a bit of advice. A mate has a widetrack blob with the DCCD box and has recently started grinding slightly when going into 4th at high revs and 6th. It's not that bad but is there! Will the Motul Gear 300 or Redline Shickproof be better to stop it from grinding? Thanks |
Hi
Any idea when the oil was last changed in the box? Cheers Tim |
Hi Tim,
it was done roughly 9 months ago. Ta |
Hi
In that case the oil should be in fairly good condition, so I wouldn't think it's as simple as just replacing with a fresh oil. Because of that, I would probably use the Shockproof. It's up to you, you could drain the current oil and replace it all, or drain a couple of litres and replace that with the Lightweight Shockproof. Cheers Tim |
Originally Posted by oilman
(Post 11909927)
Hi
In that case the oil should be in fairly good condition, so I wouldn't think it's as simple as just replacing with a fresh oil. Because of that, I would probably use the Shockproof. It's up to you, you could drain the current oil and replace it all, or drain a couple of litres and replace that with the Lightweight Shockproof. Cheers Tim I'll relay your information :thumb: |
or he's put the wrong / poor quality oil in??
There is that, but I would think the problem would have started straight away if it was the wrong oil. If it was poor quality oil it might have broken down quickly, leading to poor changes.
Let's hope the oil change sorts the issue.
He hasn't owned it that long and is quite new to performance cars so I pointed it out when I drove it! |
(Post 11909927)
Hi
In that case the oil should be in fairly good condition, so I wouldn't think it's as simple as just replacing with a fresh oil. Because of that, I would probably use the Shockproof. It's up to you, you could drain the current oil and replace it all, or drain a couple of litres and replace that with the Lightweight Shockproof. Cheers Tim Do you have a link to this oil as I've seen 2 different variants on eBay :confused: |
Hi
Here you go, not aware of any other versions of the Lightweight. http://www.opieoils.co.uk/p-1022-red...il-75w-90.aspx Cheers Tim |
Originally Posted by Scooby_nz
(Post 11911983)
Hi Tim,
Do you have a link to this oil as I've seen 2 different variants on eBay :confused: always in stock as with most things 0191-4103770 |
Hi Tim,
I hope you are still around on here. My 56-plate JDM 2.0 Hawkeye STI (with DCCD) is going in soon to have its gearbox and diff oils changed. Please can you recommend some of the best products available to me and the quantities I would need to buy? Thank you David |
post #108 is local and will help you out............
Originally Posted by david1972
(Post 12044561)
Hi Tim,
I hope you are still around on here. My 56-plate JDM 2.0 Hawkeye STI (with DCCD) is going in soon to have its gearbox and diff oils changed. Please can you recommend some of the best products available to me and the quantities I would need to buy? Thank you David he sorted me out and I’m having mine done tomorrow |
Originally Posted by RobsyUK
(Post 12044645)
message guy at opi oil’s. he sorted me out and I’m having mine done tomorrow |
Maybe mine didn’t need it but my gear changes feel no different. peice of mind it’s been done though |
(Post 12044826)
Advice needed. 1999 Impreza Turbo gearbox oil level is on the bottom mark, when cold. Once run its not registering on the dipstick. Leave it to drain and it settles on the bottom mark.
I would like to top it up to the top mark. Not knowing whats currently in the box am I best to fill with some semi synthetic rather than full? |
Originally Posted by Veloboy
(Post 12056953)
