Gearbox oil to help syncro crunch
Hi guys I have a crunch when im changing upto 4th (not back down) Im pressuming the syncro. I have read on a lot of sites about the GM Syncromesh and its magical powers that has stopped the crunching !!!!
I cannot seem to find it available anywhere allthough im a bit skeptical. Is there such an oil that can help with this or have I got to just face up to the fact the box is going to have to come out and cost me a fortune.... What about the castrol syntrax ? I heard this is good but not suitable in a sti type r ? The car is a my99 type r by the way as I think it makes a difference that it has the dccd. Any info would be appreciated . thanks in advance |
trying using redline light weight shockproof oil
Castrol Syntrax cured my box notchyness, and crunches. Car was totally different after!
Originally Posted by mit
(Post 8769702)
So I take it thats ok to use in the type r ??? Do i need to fluch or just drain and fill ? Any idea how much it holds or just take it slowly ! |
It'll be good for your type r.
Drain the oil after a run, as it's nice and thin when warm, no flush needed. Mine had a magnetic drain plug, which i think is standard, give that a clean too.(make sure theres no big metal lumps on it! I put in 4L in mine, and it read perfect on the stick. The rear diff takes a 1L. |
I use syntrax in my type r.. its a god send.
you fill up just over the full to get third i think.. thats what i did anywat and its spot on. Highly recomend syntrax!! |
I always used Redline Heavy weight shock proof oil. Sorted out the crunches that Syntrax couldnt reach!
syntrax solved my 2nd gear crunch.
its expensive though at £12 a litre i slapped some cheap £6 comma crap in the diff ;) |
When I got my UK MY97, it had a high mileage and there was often a nasty crunch when going into first and sometimes 4th. 1,500 miles ago I changed the oil, using Redline Lightweight Shockproof. It's never crunched since, totally transformed driving the car :) It's not cheap (£17 a litre IIRC) but it's totally worth it. I used to regularly read one of the big VW forums, and Redline oils have a very good reputation for sorting our gearbox crunches and noises.
I have crunching issues and a bit of a whine in 2nd and 3rd.I was looking at the redline stuff but had been reading that its not suitable for syncromesh gearboxes, i have read this wrong?
Originally Posted by jdc1
(Post 8777087)
isnt it just masking the problem though , at the end of the day if its crunching then its fooked right ??? |
Originally Posted by wraggy78
(Post 8778997)
yeah i heard the same but about castrol syntrax...
better to use redline MT90 on the gearbox and redline 75W90 on the rear diff as they have friction modifier in them
the mt90 is a gl4 though.you need gl5 in the box right?
Update !!!
Hi I have changed the oil and used castrol driveline (syntrax)
I have now covered 200 + miles since and must say the box is sweet now seem to go after about 85 ish miles and it aint come back yet !!!! RESULT...:luxhello::luxhello::luxhello::luxhello:: luxhello::luxhello: |
Sorted mate, When i do me clutch i'll be putting some of that in then :thumb:
Any tips on how to drain the oil from the gearbox?
Mine crunches when going into 6th, so a gearbox oil change is definitely on the cards!
Can I just ask though, does your crunching stop when you change into neutral then put it into gear? |
Originally Posted by Jamz_
(Post 8862502)
Chris |
Can you update us on how to do thr tranny aswell please
do you use the castrol as an addative to the standard gbox oil, or do you put the full 4 litres on castrol syntrax in, mines a 1993 wrx import and its crunching from 4th to 5th but only when giving it some beans.
Also do you refill the oil through the dipstick or is there a seperate filler that im not seeing? thanks |
no use castrol on its own its not an additive.
just refill using the dipstick tube. if its the same as a 2001 car that is..i would think it was |
i would think they are the same, cant see any harm in filling through the dipstick as it all goes in the same place.
lets hope this works then or looks like im gonna have to spend some money |
Yep, dipstick on the classic to, only way!
yeah i replaced whole lot of oil. and refill through dipstick..
guess what .. STILL NO CRUNCHING :luxhello: gearbox feels totally different its transformed it in my opinion... gonna look at putting a six speed box in next year as on the motorway it just so needs a 6th gear..... |
This looks like something i need to do soon.
this is sounding very promising!
is this the oil that everyone is talking about as im about to order some. Castrol Syntrax Universal 75w-90 semi-synthetic gear oil
Thats the one!
Where are you based? I can get it for £9.99 with my halfords trade card. Im in Luton. |
Harlow mate not to far;) waiting for a bloke to come back to me on for sale section. I will only need 1 if he sells me the other 3 he has or i will need 4, 9.99 sounds sweet!
