Thanks for the info fella :)
W
Originally Posted by salsa-king
(Post 11866874)
If a 2litre you'll be ok and cheaper road tax too.
Without looking through the whole thread are there any reports on the reliability of the newer 2.5 sti''s from the last 2/3 years?...are mappers still hesitant to run higher boost/more power through the stock units compared to the old 2.0 sti lumps. Was just wondering if Subaru address the problems or not as it's obvious it's a great motor when built right. Just curious.
Originally Posted by Imotepify
(Post 11867253)
2 hrs drive 2 get it running on our fuel is fine, how would it run on BP ultimate without a remap? I don't drive 2 hard and haven't bounced a car on the rev limiter for a long while lol
(Post 11866765)
Could be worth a phone call to Simon at APi to get some more info on what had gone on the car etc
what the max you want to spend? You know road tax is £500 a year :(
(Post 11866521)
Originally Posted by fatboy_coach
(Post 11866747)
I think that's a good price if you can land it for 11-12K. I was talking about 12K for my 08 which has covered more miles and is forged to a similar standard
Too long a thread to read the whole thing but does the 2007 Hawkeye 2.5 WRX suffer the same issues as the STI?
Great effort! This thread contains all the info you need.
In short. Yes. |
Without reading this thread at all I was under the impression the Hawkeye 2.5 WRX was a lot less likely to give up due to ringlands/HG than the hatch WRX/STI models?
Correct.
But they still do suffer the same problems. All newage 2.5 engines from 55 reg upwards have these issues. No 2.5 engine is safe, some are worse than others.
People with 70K+ 2.5 mileages would disagree with you.
Higher mileage engines don't mean they are immune to the potential issues, it just means the problems haven't presented themselves yet. The design & build faults are still present and the potential is very much there for failure on any of the 2.5 engines.
Never said it did, but you always make out they every single 2.5 is going to fail at some point, which is definitely not the case or true, especially with standard engines running with a decent map. After 2008-2010 ;)
I don't always make out that every single 2.5 is going to fail and as a multiple 2.5 owner I have always loved the 2.5 engines. I would have them time and time again, but will always be cautious of the potential 2.5 issues rather than being blinkered by them.
My 06 WRX 2.5 (that I owned since it was a year old) was amazing and massively over-serviced by me throughout it's life by only the best engineers. I always drove it with a massive amount of mechanical sympathy as I always do my cars. When I sold it back to Subaru at 75k miles this year, it too demonstrated the early signs of head gasket failure. Thankfully my dealership were also well aware of the issues and prepared to look into it and sort it out. No matter how careful you are there is still a chance of failure. I'm not saying every engine will fail, because they won't. But the potential is there without a doubt. That said, I'm still driving a 2.5 and I still love them just as much! :) |
Originally Posted by bioforger
(Post 11883897)
The 2.5 was a step too far in reality, they all have a tendency to crack across cylinders, the oil pick up pipe and head gaskets are also worth mentioning, and its on both the EJ257 AND EJ255. Of course it doesn't mean they will all fail, but it does mean the failure rate will probably be considerably higher than expected of this type of engine. |
Yea well any engine has the potential to fail at some point ;) Most manufacturers have issues of some sort or another.
Blinkered ;) not at all, but if you take everything written on the net to heart, you would never drive a post 2006 subaru ever again. This site especially is prone to blowing (no pun intended) the problems way out of proportion. Yup 2006, i'm not surprised, i think subaru definitely cleared up some of the manufacturing issues, especially for the HG bolt problems though after 2010, i guess it depends on who you speak to about that and what you are willing to believe. To put it into perspective every single car i've owned has either blown its HG or warped the head or worse. But none of the Subarus i've owned (including an '06 sti briefly) ever have... must be good luck ;) |
(Post 11883903)
Even after 2010 the map wasn't great and the inherent issues built into the engine are still there which are potential failures waiting to happen.
(Post 11883905)
Blinkered ;) not at all, but if you take everything written on the net to heart, you would never drive a post 2006 subaru ever again. This site especially is prone to blowing (no pun intended) the problems way out of proportion. Yup 2006, i'm not surprised, i think subaru definitely cleared up some of the manufacturing issues, especially for the HG bolt problems though after 2010, i guess it depends on who you speak to about that and what you are willing to believe. To put it into perspective every single car i've owned has either blown its HG or warped the head or worse. But none of the Subarus i've owned (including an '06 sti briefly) ever have... must be good luck ;) I've owned 2.5 Subaru's, rotary RX8's high powered rotary RX7's, SR20DET Pulsar GTI-R's which are supposedly prone to bottom end failure and many more on the "worry list". It always makes me laugh and it's never put me off buying or driving any of these cars daily. Realistically the Subaru 2.5 problems may put off a few people as it's very well documented now, but most will just grit their teeth and buy one anyhow hoping it doesn't fail like I do! :) If it fails, rebuild it stronger, better and faster! |
:lol1: absolutely and if it does fail for me then i can fallback on my 3rd party 5yr warranty. Although that isn't worth the paper its printed on either if you believe the forums :D
Well I'm so glad I've decided to look on here again
Had a 2005 wrx and loved it Now been looking at a 2015 wrx sti But this engine problem seems a big put off |
Originally Posted by Matty Door
(Post 11886942)
Had a 2005 wrx and loved it Now been looking at a 2015 wrx sti But this engine problem seems a big put off I didn't think there was a problem with the 2015-on cars |
(Post 11886964)
will that be fix on a Warranty claim with Subaru?
Personally I think It's disgraceful that Subaru haven't addressed the issues and continue to build engines with the same known faults.
That said, It's keeping Paul employed! :) |
like any engine, if you push it far beyond its boundaries its gonna go wrong. ive got a 2.5 and on 70,000, touch wood no problems so far.
The problem is that some of these fail without having to be pushed due to manufacturing defects from Subaru they fail to acknowledge & rectify.
Yea but the bearing failure one must have been due to a feckup in the factory build. You could argue the same for the one he mentioned that failed at 8K, also you don't know how it was treated by the owner. Too many variables. On the other hand it could have failed due to a defect as you mention, but you don't know.
(Post 11887398)
Not really. You can't say that ringland failure is due to a factory build issue. It's a weakness in the piston structure and design that causes that particular failure which is very often promoted by a poor Subaru map. |
Yea sure you can, if the tolerances with the rings were off when the engine was built it could cause it. You just don't know.
