98 99 Immobiliser problem? Still!
The Impreza wouldn't start this morning, after checking myself, and the RAC Recovery taking a look as well it looks like it may be the Factory immobiliser.
It's a very early MY99 Sport, with the coded key to ECU immobiliser, plus a Autowatch 239ti thatcham immobiliser for insurance purposes. The Autowatch immobiliser seems to work as expected with the LED turning off once it's little fob key inserted, which indicates it has been disabled. Inserting the Subaru key into the ignition the car wouldn't even attempt to turn over. Dash lights came on, with the "Engine Check" light staying on, oddly the little key symbol for the factory immobiliser looked to be off. Any ideas? The car would turn over and attempt to when the RAC chap applied power to locations under the bonnet, but car just wouldn't start. |
From what you've said I'd suggest that, if it does turn out to be a security based issue, the Autowatch immobiliser is the more likely source of this problem, simply because the Subaru transponder based immobiliser will allow the engine to turn over on the starter - it just won't allow it to start.
If it won't even turn over, the other obvious causes would be a duff starter or key switch - although one would presume that the very nice man will have ruled these out. If it is security-related, the inference is that the non-factory fit immobiliser locks out the starter circuit, and that the immobilisation relay is past it. |
I'm quite sure, you can bypass the immobilizer with the code entered into the keypad..
MY99 RB5, has the same setup, but i have the M30 Sigma installed too... |
was it parked in its usual place or at a totally different location?
Originally Posted by SiV6Si
(Post 9735885)
Thanks for the replies, the Autowatch does have overide process in case you lose the key, but when I made a brief call to the guys that installed it he said the overide process (Another company posted the proccess here http://www.abacuscaralarms.co.uk/man..._prog_keys.pdf ) doing the overide would only disable the unit in the same was as the key.
Car wise no unusual locations just in the road at the girlfriends. What did seem odd about the factory immobiliser was even without the key in the igntion, I can't recall seeing the key symbol on the dash flashing it's LED to indicate it was armed. |
Following on from the above, could the induction loop that sits around the ignition barrel go faulty
Have had the car in the dealers and have had a partial resolution. They said it seems the Autowatch Immobiliser was faulty which stopped the car even attempting to start. Immobilised through the crank signal line according to the garage. Started after they replaced the Autowatch unit.
They did find though the OE immmobiliser lamp still didn't work. Picked the car up Friday and all seemed initially ok, went to back to my family last night no prob. Have had to return the Scoob to the dealers as of lunch time Saturday. Went out 9am started car for 30 secs no problem then went back in the house. Went to start it at 10:30am and it would turn over quickly but not start, or vaguely kick into life then die within a couple of seconds. Kept doing this very occaisionally starting. Anyway as the garage was 30 odd miles away I got it running and back to them to investigate further. Any ideas? As it seems to start then die wondering if something up with the factory immobiliser too? |
