When to change sti timing belt?
Hey all,
My motor is 2.5 and I only do 1-2k a year. When the engine was built I had the sti belt fitted, any ideas when this should be replaced on a low miles motor? |
std belt interval is 50,000 miles or 5 years if I recall
Than for that.
Anyone been quoted for sti belt and changing it, inc adjuster...had price of 700 notes! :freak3:
Highly recommended and woth taking a day out.......
http://www.tdracing.co.uk/vehicle-maintenance-services/ |
Slowboy Racing near Dartford quoted me £200. Not sure if this included all the tensioners though as it needs to be full kit ie tensioners not just the belt.
Originally Posted by swisstonihasher
(Post 10096153)
A good dealer will check to see the condition of the pully etc, if it needs replacing or not. Tony:) |
200 sounds pleasant and the norm, prob not inc belt...oe sti belt 100 and something notes on it's own?
(Post 10097355)
The 200 would be belt alone. I paid 320 for a kit including water pump and fitted it myself, just an idea of parts costs before labour.
Only one pulley was beginning to show wear but not worth not spending the extra really for peace of mind. As suggested a tensioner or pulley giving way can also take out the belt. I'd be tempted on belt only if it hadn't covered the miles though. The belt will suffer from age but the pulleys mainly wear |
make sure to do the water pump at the same time only few extra quid and if pump goes after youve had belt changed it will all have to come off again to have pump done, do it all now and no extra cost down the line :thumb:
Will I need that done as pump is 5 years old but only done a couple of thou miles.
How easy is it to fit belt yourself? Special tools? |
