REAR STRUT KNOCKING...BEST TYPE OF GREASE?
hi...i have a my05 wrx and at low speed/pulling away i get a knock/thud from one of my rear shocks,im led to believe its a common thing due to grease in strut drying up.i've been using the quick fix and greaseing under the dust boot on the strut and this works fine for a month or so..so now im gonna try the long term fix and repack the grease in the shock body,has anyone done this or know which kind of grease is best?
Any multipurpose grease will do, as it's a sealed unit.
I re-packed mine, but unfortunatly the knocking means the damage is done to the top bush so a waste of time. Do what I did, Remove Throw in bin get some aftermarket struts, NOT KYB's dipster |
Originally Posted by davedipster
(Post 9950289)
I re-packed mine, but unfortunatly the knocking means the damage is done to the top bush so a waste of time. Do what I did, Remove Throw in bin get some aftermarket struts, NOT KYB's dipster had kyb adjustables on my classic for 5 years now, awesome bit of kit. why so anti them? |
As a preventative measure I have repacked my rear struts and fitted grease nipples. Its quite an easy job, in fact the hardest part was removing the bottom nut from the strut, had to make some mods. I used Lucas Red n tacky grease HERE that I got from ebay. But to be honest any good grease will do the job. I would recommend fitting grease nipples as you can then fill the chamber between the bushings.
Originally Posted by DT-SPD
(Post 9950857)
Are they silent again? Mine are silent again after a good spray of white lithium grease |
Took a good 2 hours a side but I did have trouble with the bottom nuts and I cleaned up the struts and painted them etc. It turns out that they were not the source of the noise I had ( car needed new outrigger bushes ) but at least I now know that they are not going to start knocking as they are packed full of grease.
Originally Posted by Tidgy
(Post 9950291)
KYB are the oem supplier, iirc |
As above, KYB make the dreadful std shocks.
dipster |
ahh that makes sence, yeah the standard shocks are kyb, but there pretty crap lol
the uprated ones are much much better. |
(Post 9951253)
Originally Posted by s70rjw
(Post 9954157)
Did you replace with OE or uprated items. If so what did you use, from where and how much. Thanks Bob
I used PowerFlex items, about £20 each from ebay, PFR69-124 here http://cgi.ebay.co.uk/POWERFLEX-BUSH...item45f32d041d and PFR69-118 from the same seller. Quite a big job to fit, cost me £260 |
(Post 9951192)
(Post 9950857)
Originally Posted by Arch
(Post 9960256)
Can you post some pics of exactly where you put the grease nipples, interested in this.
Here are some pics, one is of the finished struts ( you can see the grease nipples ) and the other is the mod I made to help me to undo the lower nut. http://members.multimania.co.uk/dant...rearstruts.jpg http://members.multimania.co.uk/dant...tbottomnut.jpg |
fitting grease nipples is not the best idea, over time the lower part of the shock cavity could become overfilled with grease and with nowhere for the grease to go this will become an issue preventing the shock compressing.
dipster |
(Post 9963785)
dipster |
So what's the cause of the noise i have it on my rear passenger strut is it one of the bushes on the top mount is that all that needs replaced.Mine goes up and down ok and stays in position just want to get rid of noise can i do that by replacing a bush in the mount.:thumb:
Having spoken to a Subaru specialist, the rear struts knocking happening when you start moving from stationary doesn't really affects the car's handling but it can be annoying I suppose.
