Spitting oil out of breather
Morning.
Found oil on the top of my engine this morning. After a bit of investigating I've found it to be coming from the pcv breather. When I fitted a catch can I teed this to the crankcase breather, the pipe has got hot and no loger has a tight seal. If I pull the pipe off it spits oil in my face. I presume this is not good. Anyone else had this? Or am I just being a Mong? |
Looks like build time.
Perhaps blanking the dump valve and running 500 contributed. Heyho lol. |
Blank the PCV with a bolt and vent to atmosphere and see what happens, could be faulty PCV
Originally Posted by Ginge !
(Post 10548272)
Alright Tez are you saying your getting oil up through the crankcase pipe up to the catch can ? As in pcv valve is exempt now and not used.
If so and the catch can is filling with oil rather than just misting then I think you already know what's happening mate. Tim |
Originally Posted by tweaks
(Post 10548715)
What engine 2.0, 2.5?
Tez is running a standard 2.0 and about 500 horse
Sorry to here that Tez mate seen as you've just got it all together. Tim |
Yep, as tweaks says. It's a standard jdm bugeye.
Got a couple of things left to check this morning. It's a strange one because the car is running perfectly, apart from ouzing oil onto the top of the block. |
What sort of blow by do you get when you take the oil filler cap off with the engine running ??
Mick |
Not checked yet. Just having my shreddies then I'm going out to have a proper look.
Any news Tez ?
Tim |
Blanked the hole off. All seems fine. Starting to think its probably been doing it since I fitted the catch can. Breathing seems normal from the oil filler.
