missus new car?
Hi guys missus is thinking of buying this clio, i know not eveyone taste but she loves the colour plus cheap to run, i know it needs some body tlc but what whats your views on the clios as i heard they many proplems , and what to look out for when going to view it.
http://www.ebay.co.uk/itm/1208844067...fvi%3D1&_rdc=1 cheers rob http://images.ibsrv.net/ibsrv/res/sr...lies/thumb.gif |
Hi,
I work for a Renault Parts Dept. Main thing to look out for on these are the electrics ! Any lights/wiper or body electric faults could be the UCH unit which is around £300 with the programming. Check for running faults / flat spots - can be a few things either throttle peddle potentiometer (£50 ish), the loom that runs across top of engine can crack & corrode (£136+vat) or the throttle body (£260ish +) Mechanically pretty ok just common wear & tear stuff like track rod ends, whl brgs & suspension top mounts. Hope haven't put you off as the 1.2 16v are crackin little cars - apart from electrics ! Hope helps, |
As above, electrics. I've had a few Clio Sports, nice cars but most are riddled with electrical faults. My old Clio spent 3 months in a specialist Renault garage and it still wasn't fixed properly. I ended up loosing thousands and selling it as repairs.
The common with the Clios is the electrical warning light causing the car to go into limp mode intermittantly. As a fellow Scoobynetter I'd say look for something else, if thats not an option be very careful and ensure a long test drive! |
