Secondary Air Pump Malfunction - P0410 & P2432
So late in the week the CEL came on.
I have Delta Dash and it was a "P2432 Secondary Air Pressure Sensor (Low)". Knowing this is a common issue and could just be a sticky valve that 'can' clear itself, the intention was to reset the ECU to see if it had cleared the CEL. Today I went to do this and now I have a "P0410 Secondary Air System Malfunction" code as well suggesting this is not just a one off stuck valve. Not sure really what to listen for but I think the pump is making a small amount of noise (suggeting bearings?) but it doesn't stay on after turning the engine off as per a stuck relay problem. Within the next couple of months I'm planning to get the car mapped (and hence the system mapped out). I've read plenty of threads on the subject with varying levels of failure and of course the concern is the pump over-running, burning out and melting (potentially along with the car!?). So... If i pull the relay out for now to be sure the pump won't run, is it wise to drive for a month or so or should I be benching the car until mapping (I have use of another). Any help welcome as always! |
As far as I am aware
You will have to remove the air pump and have the holes blanked of, then get it mapped out My air pump has been removed Bez |
I removed mine when the engine was out. Good working order and sat in a box. I have it in the for sale section ;)
Thanks guys. I know the procedure for deleting, blanking and mapping. Sounds like a pain in that ass but it was always on the cards when I got the card mapped.
It is more what I can do in the meantime with before that which concerns me. |
Take unit out n blank the pipes off the unit rather than the back of the engine
Originally Posted by cuprajake
(Post 11114463)
Trust me Jake i'd be buying yours if i wasn't mapping it out - good price ;) |
BUMP - just wondering if anyone knows if removing the relay will cause detrimental results for a month or two?
If you was to remove relay, the pump would not run, as I am sure you are aware, this will show a Fault code, but the engine will run fine, Your cats will not get the pre heat from the pump,
So in short, Yes, CEL light will be on all the time, by the sounds of it, its on anyway, If your ECU shows any serious faults engine will go into limp mode anyway. Bez |
Originally Posted by Bez300
(Post 11114868)
