jassa13
Hi Guys…. Im after a dump valve for my Scooby…. It’s a 1999 classic so first of all any suggestions to which one?? Secondly Iv found a couple on ebay that have the triangular fitting to mount the intercooler but are off the later model (2002 onwards) was wondering if this would fit??
Can I buy for example any HKS one and then buy the fitting kit separate or a dump valves specific to models??
You don't need a dump valve, your Scooby should already have one fitted, as as the Subaru OEM one, that is most likely fitted to your car, is one of the best out there then no need to change it
Look I've saved you a load of money
