Cheers for the replies guys, I can rest easy knowing I won't do any serious damage in the short term. As I said it wasn't so much about power at first that I changed, more about the standard sti exhaust system falling to bits and needing a replacement.
wrxsti280
As dj says, you will be fine without a map to start with, but if you can stretch to a map then that will get the best out of it, you could go for an esl, apexi or similar, for not much more than around 400 quid.
I would imagine your car will be the same as mine with regards to sensors etc, you should have a cat on fire sensor in your current downpipe, which you just disconnect and blank off with a blanking plug in your decat downpipe, your lambda sensor should be in the headers.
Yeah it's fitted now and I have to admit took a little while to get used to the loudness of a Kakimoto decat but I'm loving it. It had the cat on fire in my original downpipe. The new decat downpipe is heatwrapped so hopefully that'll be okay.
housty-wrx
alot of people will say u NEED a map....thats what they told me but im running a full stainless decat with no probs without a map
I'm not feeling an increase in performance really, so I guess I'll get a simtek ecu for the dual maps in the next few months.
Mapping for v-power gives better performance/economy? Something I've noticed is that it smells like I'm running rich and there's a fair amount of popping on the overrun, is that normal for decat or just due to the map not being setup for decat?
