vtecsti
so what gives the sti more power than the wrx if there are no differences?
If you're talking v2 1996 .It's the forged pistons and ecu tuned for an extra 10ps .I'll have to double check my cam profile data I can't remember if the cams had more duration and less lift on the sti. It's the sti v2 ra engine you want. If you can find one.
Intake Manifolds on V1/2 can't directly interchange with v3/4 directly as the tps and idle valve are different but could be used if modded
