I'm coming near the end of an engine rebuild and getting to the stage where I doing things that I hadn't intended on but might as well while the engines on the bench. You know the thing, new oil pump, new hoses, new fuel rails, etc...and a baffled sump as it will defo be seeing some track action.
Anyway, I pulled off the old standard one and ordered a new baffled number and waited for my impressive piece of kit to arrive.
See if you can spot the difference....
Before
After
Is it just me or is it the exact bloody same exept with 2 plates welded on and a seam around the top plate. I've seen the fancy custom ones but was expecting a bit more. Opinions??
