[QUOTE=cw42]
right, first off, what is the heating element shaped thing in ringed in red here for? the other 2 red circles are to show 2 mounting points, one of which is taken up by one of the current horns, the other on the left is free.
I would say that is the power steering oil cooler
this is the 1st of the 2 horns, as you can see, there is a spade wire going to it. does that have a live and neutral in it, as it's only the 1 spade, not 2!
The one wire is the live switched ,the horn must earth through the body
a side top view of the 2 horns already in place, with the single wires going to them, if I splice into these wires, will I be able to just re-wire the hellas in?
an artists impression of how it will all look when it's finished
still need to relocate that yellow ringed element though, any ideas?
Might be a bit of a job trying to relocate the cooler,
Chris i assume you are removing the oe horns ?
