Originally Posted by Hanslow
I thought a change in law was introduced around June last year that state that such things as Leylandii can only be up to a certain height and have to be lopped off if above it?
Found a story on the beeb about it
here.
Should give you something to start with......
While most of this applies
A hedge must be evergreen, more than two metres high and blocking out light, access or reasonable enjoyment of neighbours' property for it to be considered offensive
Does 3 trees constitue a hedge? As this is what the legislation covers.
