Phildodd06
Surly it would smoke all the time? not just 1 puff of smoke on cold start up?
could be the pcv valve on inlet manifold knackered causing crankcase to pressurise when boosting and forcing oil in to the turbo inlet pipe.
if i were you i would fit a catch can and blank off the pcv and see what happens then.
