" Once Subaru Fast2 is installed you need to go to SUBARU-FAST2 in your start menu and select "2) Setup"
In part 1 you should browse and select the folder you expanded the RAR file into.
This should mean you can use the software without having a CD copy in your drive.
At this point you should also click the box for "RHD" - you'll find it second from the bottom...
when i do this, and brouse, i can not find the folder, but when i look for it the normal way on the comp, i can?
