had 2 header tanks let go,one leaking on the exhaust manifold(leaked from the join and only when hot and under load) and one on the top return pipe sprayin back and dripping down(this one was a pig to find).replace all standard tank's with alloy is what i say. you never know if your lucky it could be htis as it's a simple bolt on job.good luck.
mik.
