Waste gate n dump valve
What's the difference between a dv and an external wastegate??
I have a feeling my standard wastegate on my uk turbo2000 may not b functioning correctly as it appears to be running on actuator pressure only (0.5 bar) as opposed to 0.8-0.9 all the hoses are fine and I've cleaned the boost solenoid propperly and I can hear it clicking as it should the car is not in limp mode and I've had this confirmed. Is it possible that my bailey dump valve is at fault?
