sounds (looks) like the plasterer renderded the wall in one thick coat, he should have scrath coat (base coat) it first let it dry a bit then 2nd coat it , then leave for a day then skim, if you put render on in 1 coat to thick it will crack when it drys.
Render done right is much better than dry lineing >> dot and dab
