2.5 pistons
on
2.5 pistons
hi guys i am new here and wanted to ask if any cheap better pistons for a 2.5 block 05-07 .
i got an engine 2.5 block with 2.0 STI newage heads ,mdx321 turbo , pink injectors ,decat up-pipe,full miltek exhaust with sport cat and in 2 week going to be fitted to my wrx wagon bugeye .
will be fitted all engine loom and converted to STI avcs plus ECU remaped at about 350 360 bhp and very good torque. i can t wait to drive it ))
as i read and know 2.5 pistons are not very strong and wanted to see any recommendation for a good set of 2.5 pistons with or without rings .
thank you
thank you
on
Mahle
Woosner
Jp
Cosworth
Omega
Plus many more.............
Many many types that are all good when suited to correct application, some are noisier than others due to clearances.
Get in touch with any of the builders on here who should all be able to help you out.
Woosner
Jp
Cosworth
Omega
Mahle
Woosner
Jp
Cosworth
Omega
Woosner
Jp
Cosworth
Omega
Omega here and their not noisy at all !!! honestly
on
i havent looked into all the options but of what i have looked at Wiseco's from across the pond seems cheapest. if i forge mine thats probably what ill use as they have a good rep and have been around for ages over there, maybe lesser heard of over here though.
99.5mm
http://www.ebay.co.uk/itm/Subaru-EJ2...item3a66293dd7
100mm
http://www.ebay.co.uk/itm/Subaru-EJ2...item3cb8148266
both sold with no additional customs/import duty.
99.5mm
100mm
on
That's £320 PLUS import taxes of approx $144 (dollars) so we shall call it £80 for arguments sake so that's £400 which you can purchase pistons here for less or near enough same money imho (obviously brand specific), and that's if you don't still get hit with some kind of charge.
And Maz I won't forget the name of them after the head scratching that day you took me out got there in the end tho that RB5 was fun
Lol, I still sometimes forget now ! Even though the rb5 has long gone my spec d has them fitted .
on
"No additional import charges on delivery.
This item will be sent through the Global Postage Programme and includes international tracking."
on
Nah no import tax. On eBay it will say you might get charged if its normal international shipping but sellers that use the international seller program or whatever it's called then you get listings like those two where theres that bit above the shipping price that tells you that you won't get hit with import duty. Trust me, I buy nearly everything on ebay lol
on
Yes they will, you just need to get the gaskets right for the correct CR. The smaller o.d. on the 2.0 heads do give a small step in the 'squish' area, but ive found that it makes little/no differnce. Ive tried them machined out as well.
on
I've bought from us before now and some have made it through easy enough and others get stuck in customs.
The ones I always found got stuck in customs were sent with the American postal service iirc which 99% time turned up with parcel force who just love to shaft you
on
its hit or miss usually but if you see listings on ebay with that bit saying no additional import charges, etc. then they are using the international seller program or whatever it is and you wont be hit with import duty.
bluebullet29
05 October 2015 02:17 PM
