0.5bar?
Old 17 April 2014, 08:57 PM
chieftain333
chieftain333's Avatar
Default 0.5bar?
so ive just picked up my 2003 blob sti up from the dealers and it wont boost over 0.5 bar. he mentioned to me that he HAD to put some normal unleaded in the car,has this caused it to go into limp mode? how would I reset it or am i looking at pipes,solenoid,actuator etc?
any help would be apprieciated
Andy
Old 17 April 2014, 09:05 PM
JonMc
JonMc's Avatar
Newages can only be reset using a OBD2 data monitor but unleaded wouldn't normally cause this. Could be a number of things as 0.5bar is wastegate pressure - could be amissing 'pill' in the boost hose, faulty boost solenoid or limp mode as mentioned. If it islimp mode you should have an engine managwment fault light and some codes thar will need checking.
Old 17 April 2014, 09:17 PM
chieftain333
no engine warning light.
It had a diagnostic check a few weeks ago with the same issue and he found the turbo to manifold clamp adrift + fouling valve linkages (his words) and refitted the clamp.
where is the pill located?
Old 17 April 2014, 09:19 PM
JonMc
JonMc's Avatar
The hose from the turbo to the boost solenoid has the pill. If it's a 3-port solenoid it won't be there, but if it's 2-port it will. Just fell the hose for a hard lump.
Old 17 April 2014, 09:44 PM
wrx_2005
wrx_2005's Avatar
Andy
did you get it sorted, your not far from me, I am Bradford 7 based.
Old 17 April 2014, 09:57 PM
chieftain333
havent had chance to look tonight mate,its the 2 port solenoid. im gonna have a proper dig around tomorrow,ive checked all hoses and they look fine and secure.
are you pretty handy with scoobs? would be good if you could have a look if I cant find anything untoward with it
Andy
ZigUk
8
16 May 2012 10:35 PM
geeforce
3
16 December 2010 09:38 PM
AkCustomz
12 December 2008 07:26 PM
TingTongPJ
19
22 July 2008 02:24 PM
UHF
9
31 March 2003 05:49 AM
Quick Reply: 0.5bar?
