Fitted HKS Air Filter but..
sounded and drove absolutely crap ,Missing,Air filter sounded crap, Checked pipes all ok,MAF Adapter checked all ok, Have I done something wrong?
This is what I've done
Bought a HKS Filter (Green Mushroom Type)
Bought an Adapter for the MAF connected everything.
Would appreciate any advice.
Thank You in advance
I fitted the same filter on my RA Version and was the dogs b......,cant understand what's happening to this car...
Thanks for the replies though guys appreciate it
Supporting Member
Some induction kits are better than others, but IIRC the HKS ones use oiled sponge filters which can coat and damage the MAF sensor which is why you're typically advised not to use them.
My WRX ran poorly with an HKS kit, took it off and replaced with the standard airbox and worked fine.
Best bet if you want an induction kit and aren't going mega power - buy the K&N Apollo and fit a cold air feed to it - I've seen some terrific gains from members of our local group who run them.
2. K&N are oiled.
I wouldn't use either with MAF but I have used HKS panel filters with no issues at all. The main problem with HKS foam is people think they are re-usable but the foam elements should be changed yearly
I was running a K&N typhoon with the filter in the wing with cold feed through the foglight, just for a laugh i got hold of a Honda s2000 airfilter from ebay and stuck it on... car holds much better boost through the rev's and feels alot faster, i found this as a shock
aaron_ions
17
03 November 2021 11:07 AM
Scott@ScoobySpares
Full Cars Breaking For Spares
61
11 January 2021 03:08 PM
blockhead
Subaru Parts
19
07 November 2015 11:50 PM
MH-Racing
Subaru Parts
18
18 October 2015 04:49 PM
