insanely stubborn suspension boltd
Old 02 September 2014, 06:08 PM
dabiscuit
dabiscuit's Avatar
Default insanely stubborn suspension boltd
Hi ya'll.
Anyone got any tips on removing bolts behind the brake disc? I have managed to fit coilovers to one rear corner of my car. The other side is just too hard for me.
It is anti clockwise to unscrew isnt it? Not me going mad.
I dont have an air gun just a decent set of tools. Tried wd40 and other grease/rust removers, brut force, hammers even shouting at it. They just won't budge!
Old 02 September 2014, 06:49 PM
scoobyskool
scoobyskool's Avatar
Lol shouting didnt work !! did you throw the F word at it ?
I hate these theres always one nuts etc ,,, i find shock and unlock type stuff much better then wd40 though for un seizing nuts etc ,,, six sided sockets are a must so they dont slip
I previously had a landy and they seem to suffer from a lot of seized nuts so i picked up a handy little butane blowtorch cheap off ebay that often allowed some pinpoint heat directed at the offending item which can free it up ,, ill try find a link
Edit - one of these i got as im scared of the damage i might do with a full size blowtorch but these get things well hot when needed as well as can solder with ithttp://www.ebay.co.uk/itm/IRODA-MICR...-/270955631270
Old 02 September 2014, 07:27 PM
Paben
Paben's Avatar
Hex socket as above and if I remember correctly you have to lock up the nut with a spanner and actually unwind the bolt. A massive breaker bar was required for mine, although an air gun would be the ideal tool. Once your coilover is fitted you have to tighten the bolt again with the nut just locked in place with the spanner. This doesn't seem ideal but it does the job and mine haven't fallen off yet.
Old 02 September 2014, 07:47 PM
dabiscuit
dabiscuit's Avatar
Ive heard of the blow torch trick. Thought about sitting there with a lighter under it!
Might ask a nearby garage if I can steal their air gun for a few minutes.
I managed the other one with a hex bar and a spanner and lots of f'ing and blinding.
Old 02 September 2014, 07:49 PM
Turbotits
Turbotits's Avatar
A large breaker bar should do the job.
Old 02 September 2014, 08:44 PM
J.e30
J.e30's Avatar
heat is your friend, and a bigf-ing bar
Old 02 September 2014, 11:17 PM
hooley scoob
hooley scoob's Avatar
breaker bar sorted mine
Old 02 September 2014, 11:28 PM
LSherratt
LSherratt's Avatar
1/2" 6 sided socket with long breaker bar and a hammer will undo virtually any nut.
Old 02 September 2014, 11:29 PM
Fonzey
Fonzey's Avatar
Not sure about "other grease/rust removers" but WD40 is worthless for undoing stuff.
I struggled with the same bolts on my car, NOTHING budged them and the motor in my mains powered rattlegun started smelling a bit ugly!
I then went to a motorfactors and got "Plus Gas" and it unseized them within about 20mins.
Old 02 September 2014, 11:57 PM
ST-X
ST-X's Avatar
I used a 3.5ft breaker bar on a 6 point socket and had the bar so bent with force that I thought it was going to snap before the bolt finally broke loose! Go for loosening the nut first rather than the bolt too, it's usually easier to free them off that way first.
Old 03 September 2014, 07:31 AM
ditchmyster
ditchmyster's Avatar
Proper penetrating oil is a must, forget WD40. Small wire brush give the threads a good scrub and spray liberally, then walk away for an hour or two. Ideally I always do this the day before and usually twice before I even get involved with trying to undo rusted bolts.
Old 03 September 2014, 10:06 AM
Matt_STi
Matt_STi's Avatar
breaker bar and lot of screaming like a girl did it for me!
Old 03 September 2014, 10:34 AM
JDM_Stig
JDM_Stig's Avatar
if its the 2 big fixing bolts you would be better undoing the nut, if your trying to undo the bolt you are trying to undo it and all the rust that`s holding it in place,
the nut will come off with less torque required,
I use a socket with T bar then use the trolley jack to undo it, worked on dozens of cars for decades until I got an electric impact gun lol
Old 03 September 2014, 11:36 AM
sovietspybob
sovietspybob's Avatar
I've used the breaker bar and trolley jack trick a few times, think i just stood on the end of my breaker bar to do the bolts of my suspension. I've heard soaking the area with coke can work but people say you can use coke for anything!
Old 03 September 2014, 12:51 PM
NotFromSomerset
NotFromSomerset's Avatar
Buy an electric impact wrench. Saves you so much time with stubborn bolts. Worth their weight in gold
Old 03 September 2014, 05:35 PM
dabiscuit
dabiscuit's Avatar
Well I used some loosening stuff let that settle for a bit and borrowed a 28" breaker bar from a nearby racing team (recently discovered), started with the nut and eventually did it, but **** me was it had work.
Feel like I've played rugby (which I do).
Rear coilovers on, fronts tomorrow. Did a 30mm drop at the rear. See how the splitter fares with a 30mm drop at the front. No camber and set to soft for a more comfortable ride (one hopes).
Cheers for all the help!
Old 03 September 2014, 05:45 PM
andy97
andy97's Avatar
Location: Api 500+bhp MD321T @91dB Probably SN's longest owner of an Impreza Turbo
Today would be the best to clean rusted threads on the front suspension and apply necessary thread un locker fluid, leave overnight for best results.
Old 03 September 2014, 06:11 PM
cookstar
cookstar's Avatar
Failing that a couple of cheeky lines of the stuff makes any job more enjoyable.
Old 03 September 2014, 06:31 PM
joe v3sti
joe v3sti's Avatar
Your best bet is to Grow a pair of ***** and get 2 spanners, push one away from you and the other towards you.
Job done!
Old 03 September 2014, 06:32 PM
joe v3sti
joe v3sti's Avatar
I'm only kidding. On a serious note, have you put some heat on it yet?
Joe
Old 03 September 2014, 07:13 PM
dabiscuit
dabiscuit's Avatar
Tried the muscle route, alas I am not strong enough! Blistered hands though
Driftworks.com were good to me. Not only did they throw in some degreaser with my coilovers but they gave me a free wham bar! (Not to be used ad a breaker bar). Didn't know they still made those.
Anyway white lithium grease is doing its over night.
As a noob attempting my first coilover install I can safely say it is simple to do just requires patience and strength and I'm very impressed with the build quality and ease of adjustment of the coilovers. Lets hope they ride well.
Old 03 September 2014, 07:43 PM
scooby_Paul
scooby_Paul's Avatar
I had to get the oxy acetylene out at work and warm em up as mine was solid
Old 03 September 2014, 08:39 PM
PODWRX2
PODWRX2's Avatar
Take it to your local garage and ask them to get the impact gun on it for you - problem with spanners and sockets is that if they slip and round off the corners your screwed. They should only charge you a few quid if you know them well enough. Oxy is more fun though!
Old 03 September 2014, 08:42 PM
joe v3sti
joe v3sti's Avatar
Go buy 2 good quality hex 6 sided sockets
Old 03 September 2014, 08:56 PM
The wife did mine.
Old 04 September 2014, 10:20 AM
DIPSY
DIPSY's Avatar
Clean the thread and run a nut up it the right size cleans the thread up perfect.Give the hex head of the bolt a few cracks with a hammer or punch and hammer if you can get near with hammer .Use the hammer and punch on the hex faces of nut as well
KAS35RSTI
Subaru
27
04 November 2021 07:12 PM
Mattybr5@MB Developments
Full Cars Breaking For Spares
12
18 November 2015 07:03 AM
the shreksta
Other Marques
26
01 October 2015 02:30 PM
LSherratt
Non Scooby Related
20
28 September 2015 12:04 AM
4
27 September 2015 03:39 PM
Quick Reply: insanely stubborn suspension boltd
