Not sure weather it would fit I had it in my blob for a week but couldn't put the seat back far enough so removed it all I can say it was tight in the blob so would think it would be ok for a classic
I spoke to the manufacturer about the issue of not being able to get the seat right back with a harness bar and they said they had heard nothing about it despite a number of hits found when searched on google. Can I ask what you have gone for instead mate? I'm in the position of fitting new race seats but want to run harnesses mounted at the correct angle.
I'm quit tall and like to have the seat right back and as I was driving all the way to spa and the ring needed to get the seat comfortable
I used the seat fixing on the tunnel side with a harness bolt ring and then drilled the floor on the other side and the the shoulder straps fixed on the isofix mountings behind the rear seats hope this helps
Yeah I'm tall also and have the seat right back. I wondered about using the bar as a pivot for the harnesses so they were at the correct shoulder angle and then taking the ends back to the rear seats? Just can't decide weather to try it or just stick with the OEM belts until I have a cage in...Off to the ring in a couple of weeks also so would like to try and sort it before then.
Anyway GLWS!
You can't beat harnesses if you on track where are you based if your close you could come over and try them
Derbyshire mate, bit far if your still London based. I have GSM sports seat near me so I'll pop over there and see if they have any other solutions for fixing the seat back issue/harness bar issue.
Sorry m8 , just saw it's for a MY 05
If it's a NR>G bar it def won't fit my MY06-7
Or I would have taken it
The reason your having probs with the seat is they come in 47". 49" 51" variants
So you been tall , I'm presuming this is a 47 " more likely
Hope this helps & GLWS
Thanks mate I have no idea of the make I didn't no there was so many different variants sound like you no much more than me I hope this helps with other decision weather to buy thanks
Do you know if this will fit in a blob with stock seats all the way back? I know you said you could get your seat back but was unsure if you have buckets
Doesnt bother me eitherway to be honest, I missed out on his thats all for £100, I wont offer you that but will go to £120 delivered can send payment now
