BLOBEYE 01G SILVER BREAKING NICE SPEC (rcm headers/porsche brakes/xxr's/bc's/whitline
Old 19 April 2014, 10:49 AM
Default BLOBEYE 01G SILVER BREAKING NICE SPEC (rcm headers/porsche brakes/xxr's/bc's/whitline
ok we have another nicely modded 54 plate blobeye in 01g silver for breaking all in excellent working order very well looked after and maintained example ..all parts will be removed later on this week so please check delivery before buying please
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
colour code 01g silver
sti semi closed deck avcs heads 03 uk spec long engine £SOLD
non dccd 6 speed gearbox £SOLD
r180 larger rear drive shafts excellent working order £180pair
r180 rear hubs £SOLD
6 speed starter motor £45
vf35 turbo charger £sold
sti larger tmic in v good con complete with genuine sti pipe work mounting brackets great for classics and newage wrx models £150
sti large under tray good con £60
oem recirc valve £sold
650cc injectors £sold
sti red crinkle inlet tgv delete inlet £sold
fuel lab 3 port fuel regulator £sold
newage sti avcs engine wiring loom excellent con uncut or modded at all £sold
full wrx car wiring loom uncut or modded minus small engine loom £100
wrx open sourced ecu with key set and barrel/door/boot locks with sendor unit £100complete
sti turbo inlet pipe excellent con un ripped ect £sold
rcm 3 bolt gt spec headers £sold
jap speed 3inch fully de catted down pipe £sold
full 3inch cat back exhaust system £sold
rcm spun alloy trumpet £sold
red silicone induction kit to turbo inlet pipe joiner £sold
samco red 4 piece water hose kit genuine samco £sold
rcm 340lph lph fuel pump £sold
Subaru early 3 post boost solenoid £sold
2 port boost solenoid £20
metal header tank good con no leaks £25
sti 1.3 bar rad and header tank caps £sold
air con pump excellent working order £25
air con condenser rad good con £25
radiator with twin fans good con no leaks etc £40
washer bottle with pumps £15
intake snorkel £10
alternator cover £10
battery claimp and threaded bars £10
WHEELS/BRAKES/SUSPENTION
as new 18" xxr 527's £sold
power station Porsche huge 6 pot front brake £sold
newage brembo rear brakes re painted red excellent working order awesome stopping power with good standard disks and uprated pads loads of life in them 100pcd fitment so fit all year cars great wrx or classic upgrade £250 will not split
bc br coilover suspension £sold
whiteline adjustable 22mm rear anti roll bar £sold
whiteline 22mm front anti roll bar good condition complete with bushes £90
whiteline billet rear c shape drop links £sold
whiteline anti lift kit full kit all good condition and complete £100
front strut brace £sold
rear strut brace pink ends £sold
front subframe good con £40
front lower u brace good con and solid £45
rear subframe good con £40
rear trailing arms good con £30set
steering rack steering rack £40
pas steering pump in perfect working order £60
pas pipe with with remote bottle and cooler £30
EXTERIOR BODY WORK
front bumper £SOLD
rear bumper £SOLD
front grill with badges excellent con £SOLD
blobeye alloy bonnet in good con with genuine sti high level scoop all painted less than a month ago no damage or marks £250 WILL NOT SPLIT
de tango's and black headlights £SOLD
standard blobeye head lights £sold
blobeye tail lights £SOLD
blobeye sti wings £SOLD
prodrive limited edition side skirts £sold
prodrive edition sti rear hi level spoiler £sold
replica roof spoiler £sold
boot lid excellent condition only painted less than a month ago so no marks or damage at all looks great (NO BOOT LOCK FITTED) £70
4x doors all excellent condition only painted a month ago no damage or marks £30each
wing mirrors very good con painted less than a month ago so looks great £45pair
fuel filler door £15
front window good con £45
tinted rear heated screen good con £45
tinted rear side windows look great £30pair
side mouldings trims £20pair
roof gutter trims £20pair
INTERIOR
jvc double din head unit top of the range system ipod/mp3/blue tooth/usb remote control all as new condition and with box ect easy to use and looks great £120
depo boost and oil temp gauge in double gauge A piller pod £sold
road angle speed camera detection system excellent working order a real licence saver system easy to use £40
wrx momo leather steering wheel in good con with air bag and clock spring for easy fitment £40
prodrive bugeye sti seats £SOLD
sti door cards £SOLD
grey carpet good con no rips etc £30
sti 6 speed red stitch gear **** £25
hand brake lever £10
centre section good con with arm rest £15
wrx clock set excellent working order £30
carbon look stereo surround decal over original silver looks good fitted £25
carbon look heater surround with vents carbon look sticker over original silver looks good fitted £15
newage dash top good con £30
boot carpet £25
sti boot over carpet looks great and perfect fit £25
boot side liners good con £sold
spare wooden wheel cover £20
Old 19 April 2014, 10:57 AM
birchy2010
birchy2010's Avatar
Text you mush about the xxr's
Old 19 April 2014, 11:06 AM
ditchmyster
ditchmyster's Avatar
I'll take the avacs wiring loom please and samco water hoses. send me payment details please.
Old 19 April 2014, 11:14 AM
Tx replied birchy cheers
Ditchmyster we have these off ready to go already on me of needed
All pm's replied
Old 19 April 2014, 11:28 AM
ditchmyster
All pm's replied
Ok just send me payment details and full price with postage to NG5 and fees and i'll paypal you money and address.
Old 19 April 2014, 03:54 PM
Il send payment details over shortly then thank you
All pm's replied
Old 19 April 2014, 04:05 PM
TH3_5T1G
TH3_5T1G's Avatar
Location: Somewhere halfway between heaven and hell, some call it earth!
Can i have pics of the RCM headers please? Is the heat wrap starting to fray or fall apart?
The fuel pump, is it perfect fit, i.e plug and play or are there any adaptions needed?
Could i also have first dibbs please
Old 19 April 2014, 04:11 PM
TH3_5T1G
TH3_5T1G's Avatar
Also interested in the Fuelab FPR and spun trumpet with filter. Pics of those please
Old 19 April 2014, 04:46 PM
stevie turbo
stevie turbo's Avatar
hi mat pics and first dibs on front bumper winglits please (o1g)
Old 19 April 2014, 06:26 PM
Richie333
Richie333's Avatar
You have PM
Old 19 April 2014, 07:58 PM
Stig there no dibs sorry all pictures what we have have been added the headers are very good wrap is like new the fuel pump is a direct fit no messing
Stevie winglets are going with bumper only sorry
Richie pm replied
All pm's replied and pictures added
Old 19 April 2014, 08:16 PM
TH3_5T1G
TH3_5T1G's Avatar
You have PM
Old 19 April 2014, 08:47 PM
domino46
domino46's Avatar
This was one of our club members scoobs and it was very well looked after
Old 19 April 2014, 08:50 PM
Markfey
Markfey's Avatar
Fpr please Matty.
I need a power steering pump as well for v4 classic.
Might have a taker for the gauges as well
Old 19 April 2014, 09:15 PM
Stig pm replied thank you
Dom thank you matt did a outstanding job on the car indeed
Mark sorry we don't have the pas pump and fuel reg is still for sale at the moment mate
All pm's replied
Old 19 April 2014, 09:31 PM
Milneragain
Milneragain's Avatar
Matty
I am interested in the tail lights for my hawk, as long as they are in as good a condition as they look.
How much for delivery to N Ireland?
Old 19 April 2014, 09:38 PM
Markfey
Markfey's Avatar
Cash sent buddy
Old 19 April 2014, 10:43 PM
Milner they are excellent condition postage is £15 to n.i fella pm me if needed
Mark thank you we have that it be posted Tuesday thank you
All pm's replied
Old 20 April 2014, 06:32 AM
mctwistuk
mctwistuk's Avatar
How much for front wings posted to Glasgow Matty?
Old 20 April 2014, 09:43 AM
robj2502
robj2502's Avatar
I will take the rear trailing arms, rear brace and the whiteline ALK (I assume this fits the sti alloy arms?) Could you pm price posted
Old 20 April 2014, 06:18 PM
Mct postage is £12 for the wings as there large items pm me if needed
Rob yes all thoses items are still for sale mate postage would be £9 for thoses pm me if needed we sort it out
All pm's replied
Old 20 April 2014, 07:57 PM
Inviroman
Inviroman's Avatar
Price for both down pipe and full exhaust posted please.
Any pics of the full system?
Old 20 April 2014, 09:35 PM
Postage is £12 for the full system we only have the pics that are up at the moment tho sorry
All pm's replied
Old 21 April 2014, 09:07 AM
walsallboy
walsallboy's Avatar
Hi matty still Got the road angel
Old 21 April 2014, 09:30 AM
Yes we still have the road angle pm me if needed
All pm's replied
Old 21 April 2014, 03:09 PM
mctwistuk
mctwistuk's Avatar
I will take the wings Matty will pm you for payment details.
Chris
Old 21 April 2014, 09:09 PM
GC8RAti
GC8RAti's Avatar
Hi, if you can ship to Sweden I'll take the idle control valve, throttle position sensor, crank sensor and camshaft sensor.
Thanks!
Old 21 April 2014, 09:47 PM
stealthy1
stealthy1's Avatar
Hi.as small of a part it is,my bro is after the 90' elbow for the 30mm blow off valve pipe as going back to recirc from a VTA.would you sell this and how much please?
Old 21 April 2014, 11:43 PM
Mct pm replied thank you
Gc8 yes shipping is no problem at all pm me we can sort that out for you thank you
Stealthy I take it you mean the metal pipe attached to the re circ?of so I'm afraid we sell these on the recirc only fella sorry
All pm's replied
Old 22 April 2014, 12:35 PM
Gear Head
Gear Head's Avatar
Hi Matty
Emailed you about the rear bumper.
Will definitely have it.
Quick Reply: BLOBEYE 01G SILVER BREAKING NICE SPEC (rcm headers/porsche brakes/xxr's/bc's/whitline
