BLOBEYE 03 STI BREAKING WR BLUE(porsche brakes/magnesium 18's/defi guages+more
Old 24 May 2014, 06:25 PM
Default BLOBEYE 03 STI BREAKING WR BLUE(porsche brakes/magnesium 18's/defi guages+more
ok we have another nice 03 plate blob eye sti in 02c wr blue for breaking all in excellent working order very well looked after and maintained example with 57000 miles only so nice low mileage example ..all parts will be removed later on this week so please check delivery before buying please
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
colour code 02C WR BLUE
sti semi closed deck avcs heads long engine £sold
excedy pink box uprated clutch £sold
non dccd 6 speed gearbox £sold
R180 uk spec 3.54 rear diff excellent working order £150
r180 larger rear drive shafts £sold
r180 rear hubs £sold
6 speed starter motor £45
vf35 turbo charger £sold
sti larger tmic £sold
sti large under tray £sold
turbo smart adjustable blow off valve excellent working order £100
550cc pink injectors £sold
sti red crinkle inlet tgv delete inlet £sold
full sti car wiring loom uncut or modded minus small engine loom £100
standard sti ecu with key set and barrel/door/boot locks with sendor unit £150complete
sti standard headers great upgrade great addition to wrx items also inc non catted sti uppipe £60
standard sti catted dowm pipe good con great for mot time or returning cars back to standard will fit wrx models also £50
aftermarket 2.5inch exhaust cat back system £sold
welbro 255 lph fuel pump excellent working order great upgrade part £30 or £40 with sendor unit complete
induction kit £SOLD
2 port boost solenoid £20
metal header tank good con no leaks £25
air con pump excellent working order £25
air con condenser rad good con £25
top rad hose good con £10
bottom rad hose good con £5
washer bottle with pumps £15
intake snorkel £10
alternator cover £10
battery clamp and threaded bars £10
WHEELS/BRAKES/SUSPENTION
rare 18inch sti magnesium alloys £sold
huge Porsche brembo 356mm front brakes stupidly expensive new from power station over 2k's worth all painted in brembo gold to match the rears look awesome like this awesome stopping power with very good genuine ap 2 piece disks and uprated pads both with very little wear so excellent life in them all cailpers work perfectly 100pcd and 114pcdfitment great sti wrx or classic upgrade all bolts and braided hoses inc £provisionally sold
gold brembo rear brakes £sold
sti 50mm suspension set up £sold
front subframe good con £40
front lower u brace good con and solid £45
rear subframe good con £40
rear trailing arms good con £30set
steering rack steering rack £40
pas steering pump in perfect working order £60
pas pipe with remote bottle and cooler £30
EXTERIOR BODY WORK
genuine sti bare shell complete with id and paper work some parts are left on like fuel tank and fuel lines all brake lines etc ideal projects etc £250
sti front bumper £SOLD
rear bumper £SOLD
sti front grill with badges v good con £60
blobeye alloy bonnet £SOLD
sti large genuine scoop £sold
blobeye sti headlights good condition genuine un messed with items nice and clean £250set WILL NOT SPLIT
blobeye tail lights good con great hawkeye and bugeye upgrade £100pair WILL NOT SPLIT
blobeye sti wings £SOLD
sti twisted side skirts £sold
sti rear hi level spoiler genuine item in good con no damage all genuine item and paint work in in very good order rear to fit with full brake lights and fixing £300
sti boot lid £sold
4x doors all complete with glass and internals drivers rear door does require paint work tho £30each
wing mirrors good con £45pair
fuel filler door £15
side mouldings trims £20pair
roof gutter trims £20pair
INTERIOR
defi genuine 60mm gauges £sold
kenwood double din cd/blue tooth/hands free/usb/aux head unit excellent bit of kit very easy to use and link up phone ect looks great and sounds excellent £100
sti steering wheel £sold
sti seats all excellent con no rips or tears etc very comfy and great classic or wrx upgrade front and rear seats only £250set will not split
sti door cards £sold
sti blue carpet good con no rips etc great wrx upgrade £60
sti 6 speed red stitch gear **** £25
red stich hand brake lever £20
centre section good con with arm rest £15
sti blue clock set £sold
stereo surround re done in black looks great good con £25
heater surround with vents re done in black looks great fitted good con £15
newage dash top good con £30
boot carpet £25
boot side liners good con £20pair
spare wooden wheel cover £20
Old 24 May 2014, 06:58 PM
riiidaa
riiidaa's Avatar
keen on the following pending photos of any imperfections and me working out how to get the items to me without dinging them.
sti front bumper complete with genuine winglets and fog covers good con undamaged or repairted etc and un modded some minor stone chips and small curb rash on lower part on winglet nothing major £300 WILL NOT SPLIT
blobeye alloy bonnet in good con with genuine scoop all good con odd stone chip nothing major £250 WILL NOT SPLIT
blobeye sti headlights good condtion genuine un messed with items nice and clea £250set WILL NOT SPLIT
blobeye sti wings good con nice and straight £150pair WILL NOT SPLIT
Old 24 May 2014, 07:05 PM
Pictures will most likely be tomorrow or Monday now as. Weather is not allowing me to take any good pics with all the rain sorry
Old 24 May 2014, 07:41 PM
riiidaa
riiidaa's Avatar
cool mate, regards all the items i listed, do you courier out bonnets etc ?
Old 25 May 2014, 08:44 AM
We can post yes but bonnet and fragile items alike are sent at your own risk we could pallet them which would be much safer tho
All pm's replied
Old 25 May 2014, 01:57 PM
cossie_eater
cossie_eater's Avatar
got a pic of the induction kit please?
Old 25 May 2014, 05:38 PM
Sorry we haven't got pics taken yet sorry most likely be Monday now sorry
All pm's replied
Old 29 May 2014, 06:43 PM
pics now added and list updated
all pm's replied
Old 29 May 2014, 09:49 PM
ditchyboy
ditchyboy's Avatar
How much for the bootlid posted to DT7 and has it now been checked for rust??
Old 29 May 2014, 10:48 PM
Sorry still not checked for rust I'm afraid it will be next week now before that happens postage would be £12 if you went ahead with it
All pm's replied
Old 30 May 2014, 10:08 AM
ditchyboy
ditchyboy's Avatar
Ok,if you could Pm me when you've had chance to check bootlid that would be great.cheers
Old 30 May 2014, 12:34 PM
GlennyP
GlennyP's Avatar
I'll take the induction kit. can you pm me payment details.
Cheers!
Old 30 May 2014, 10:06 PM
BoozyDave
BoozyDave's Avatar
I'm interested in the intercooler spray (is everything included for easy fitment?), boot side liner to suit.
how much for the fuel level sender out of the tank?
Old 31 May 2014, 03:09 PM
riiidaa
riiidaa's Avatar
Still keen on these bits, left you a voicemail. Might be able to come up with a friend "Anger", in a sprinter, who also wants a blob bonnet in o2c.
Old 31 May 2014, 05:21 PM
Ditchyboy boy yes will do thank you
Glenn pm replied thank you
Dave all what's inc is listed tank with pump the switch and jet you will need to make a small loom to enable it to work and no side liners to suit are seprate and listed in theist also pm me if needed
Riidaa sorry bumper and wings/bonnet off this has now sold we have have headlights and another bonnet in the same colour also tho also have a pair of wings in this colour but drivers has some lacour peel on them pm me if needed
All pm's replied
Old 01 June 2014, 10:09 PM
LIST UPDATED ALL SOLD ITEMS LISTED AND ALL PM'S REPLIED
Old 02 June 2014, 04:48 PM
stevemoir
stevemoir's Avatar
What's the minimum you would take for the porsche setup matty pm me if need be
Take it these are a direct fit to a hawkeye sti and will fit under 18x8 speedline turini et48
Steve
Old 03 June 2014, 08:12 AM
Replied Steve thank you
All pm's replied
Old 03 June 2014, 10:18 PM
ditchyboy
ditchyboy's Avatar
Sorry to keep bothering you Matty but do you know the condition of the boot lid yet?
When you say no lock supplied is that just the barrel or the actual mechanism as well?if its without both how hard are they to swap?
Old 03 June 2014, 10:30 PM
Miller-SoT
Miller-SoT's Avatar
Will you take £60 for the skirts?
I can collect Wed or Thur.
Old 03 June 2014, 10:31 PM
Miller-SoT
Miller-SoT's Avatar
As long as they are the same shape a P of P to swap.
Old 04 June 2014, 08:30 AM
Ditchyboy sorry it has rusted in the usually place it's just been patched over sorry
Miller sorry the skirts are £70 there worth this sorry
Old 04 June 2014, 08:41 AM
Miller-SoT
Miller-SoT's Avatar
Fair enough. I'll see you later today.
Old 04 June 2014, 08:39 PM
ditchyboy
ditchyboy's Avatar
Ok Matty.is it bad or visible with spoiler on?have you got any others coming in soon?
Old 04 June 2014, 10:27 PM
Jay Cartay
Jay Cartay's Avatar
Hello, how much for the cigarette lighter unit posted, presuming it works ?
Old 05 June 2014, 03:21 AM
backslider
backslider's Avatar
Matty, my friend is in desperate need of two little parts. First is the clip holding the to cable.
And the other is a bracket holding the power steering lines into the green bracket over the injectors.
He really needs them and will make it worth your time to send them over the pond.
Let me know what it will take to aquire these to parts.
Old 05 June 2014, 08:16 AM
Phil thank you for coming down nice meeting you
Ditchyboy boy sorry now it's removed we can see it's fairly bad I'm afraid and we just don't know when we get another rust free one as it's so common to find now even these low milage ones have it I'm afraid
Jay the cig lighter goes with the gear surround we don't remove them sorry
Back slider we have the parts but sorry we have stopped sending parts to the US as zits just to much hassle booking them it's just not worth it sorry
All pm's replied
Old 05 June 2014, 03:33 PM
backslider
backslider's Avatar
Matty, I completely understand, I too hate shipping overseas. If you change your mind, by all means please let me know.
Old 05 June 2014, 03:59 PM
hill79
hill79's Avatar
small parts, but hoping you'll have them - cigarette lighter and the clip that holds the drivers mat in place (just the top half)?
Old 05 June 2014, 09:53 PM
Back slider sorry it is a lot of hassle with the couriers they make it such a pain sorry we cannot help
Hill79 the cig ligter it's self we have but not the actual unit the carpet holder goes with the main carpets tho I'm afraid
All pm's replied
Quick Reply: BLOBEYE 03 STI BREAKING WR BLUE(porsche brakes/magnesium 18's/defi guages+more
