Grimmspeed 3 port
Old 27 May 2014, 10:39 AM
scoobjam74
scoobjam74's Avatar
Default Grimmspeed 3 port
Selling a 3 port grimmspeed boost solenoid I good working order great bit of kit £50 delivered
This is the description from https://www.grimmspeed.com/product_i..._500_sold3.jpg
PRODUCT DESCRIPTION
Get into Boost Much Quicker
(Flows 10% more than the competition)
Plug and Play into OEM Harness
(no splicing wire like other BCS!)
Factory Fit with clean install
Works Safely with Factory Subaru ECU
(custom coil to match ECU)
Nickel Plated Fittings as this is Built To Last
(not the easily breakable plastic fittings!)
Easy to Install and Very Easy to Tune
The Only Direct Bolt-IN BCS for all Subaru Models
GrimmSpeed™ introduces the most complete and easy to use 3-Port Electronic Boost Solenoid for the Subaru WRX, STi, FXT, and LegacyGT available on the market. Our aftermarket boost controller allows you to raise the OEM boost levels in a quick and efficient manner. If you try to raise the boost on the weak OEM boost solenoid it will start to become unpredictable and unable to maintain proper and safe boost levels. Using our solenoid you are able to spool your turbo quicker and maintain a rock solid boost level. We have made our solenoid to withstand 120psi, way more than any Subaru will see.
Revolutionizing the Subaru boost solenoid market, we have created model specific install brackets that allow you to directly fit our Boost Solenoid into your Subaru for a factory fit. No more Zip-tying! We give you the factory fitment you have been waiting for.
Staying with the OEM fitment theme, our Boost Solenoid uses a Subaru style wiring harness so you can simply unplug your OEM solenoid and plug ours in. No more cutting the oem wiring and crimping wires together!
Also new to the Subaru boost solenoid market, we have used ultra low-profile hose fittings to keep the unit as small and clean as possible. The hose fittings are nickel plated brass so you don't have to worry about them snapping off like the plastic hose fittings!
More Features:
Users can use AN fittings with the solenoid.
MAC Valve's has completely custom made the valve for us(only MAC valve on the market to be custom made for automotive tuning use).
Specifically designed by GrimmSpeed™ to work safely with the factory Subaru ECU (requires tuning) and to reliably handle the vibrations and temperatures of your engine bay!
The only direct “bolt in” design for all Subaru models. Direct bolt in mounting bracket and hardware included! (specify which model before ordering)
Faster response and greater flow than any other valve out there. (by more than 10%!)
Nickel plated brass fittings. (unlike the competitors failure prone plastic fittings)
This BCS will handle all your boost control needs no matter what your power goals are.
Easy for your shop or tuner to tune! (Engine tune is required!)
Tuner's comments on our Boost Solenoid
AWD Tuning:
"The GS 3-port BCS provides rapid boost response while maintaining the ability to make acute adjustments via turbo dynamics. While many other boost control solenoids react to adjustments too fast which can make them difficult to control with as much finesse as the stock bleed system. This solenoid can make micro-adjustments at the edge of target boost not only providing better spool, but overall more control. "
Bullwinkle Tuning:
"The GrimmSpeed™ BCS is a compact, well designed unit. Its design as a 3-port solenoid provides better boost control then the stock bleed-type style. Often, this enables a tuner to cut mapped wastegate duty cycles in half. This change in WGDC gives a tuner more granularity when tuning, and can yield much improved boost curves. In addition, the 3-port design often significantly improves spool."
Attached Thumbnails Click image for larger version
ID:	16511   Click image for larger version
Old 27 May 2014, 01:05 PM
just me
just me's Avatar
Hello is there anything wrong with the bcs?
I'll have it if you could do it £40 inc delivery?
Old 27 May 2014, 10:51 PM
scoobjam74
scoobjam74's Avatar
No nothing wrong it's in good order and it's £50 delivered cheers
Old 28 May 2014, 02:44 PM
just me
just me's Avatar
In that case I'll leave it, as with paypal fees it will be over £50.
Old 28 May 2014, 05:59 PM
Scooby-Ant
Scooby-Ant's Avatar
Ill have this if poss thanks
Old 28 May 2014, 07:54 PM
Eamonnk
Eamonnk's Avatar
Hi mate
Not quite sure my messages are getting through. If not sold will take at 50 delivered will it be ok for a hawk eye appreciate will need setting up, hopefully power station can do for me
Regards
Eamonn
Old 28 May 2014, 08:05 PM
Scooby-Ant
Scooby-Ant's Avatar
Aint it first come first served or what ???
Old 29 May 2014, 06:58 AM
Scooby-Ant
Scooby-Ant's Avatar
Well I still want it cash waiting !!!!!!!
Old 29 May 2014, 09:21 AM
scoobjam74
scoobjam74's Avatar
Sold
Old 29 May 2014, 11:50 AM
Scooby-Ant
Scooby-Ant's Avatar
Charming
Old 29 May 2014, 11:54 AM
scoobjam74
scoobjam74's Avatar
Sorry mate didn't see your post should have pm'd me I would have replyed I'm not on line much only when I can as I'm busy
Old 29 May 2014, 06:06 PM
biged4244
biged4244's Avatar
sorry Scooby ant didn't mean to step on anyones toes I just sent a pm to him didn't read the thread.
Old 30 May 2014, 07:30 AM
Scooby-Ant
Scooby-Ant's Avatar
Well that what a thread is for and you did comment on the thread after me but because im new i spose i get pushed back down the que , but never mind I actually found one yesterday on ebay more or less new for 35 qiud so im all happy anyway
Old 30 May 2014, 07:44 AM
biged4244
biged4244's Avatar
no it wasnt me my appology was my only thread,and you must have got lucky case i looked on ebay yesterday and couldnt find one for good money.!!
JimBowen
ICE
02 July 2023 01:54 PM
Quick Reply: Grimmspeed 3 port
