RARE JDM STI WIDE TRACK BREAKING (dccd 6 speed/syvecs/brembos/jdm extra's/perrin)
Old 21 July 2014, 03:20 PM
Default RARE JDM STI WIDE TRACK BREAKING (dccd 6 speed/syvecs/brembos/jdm extra's/perrin)
ok we have another nice rare wide track blobeye jdm sti in 02c wr blue for breaking all in excellent working order very well looked after and maintained example sadly jdm engine has been replaced with a uk spec item but still a great car ..all parts will be removed later on this week so please check delivery before buying please
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
colour code 02C WR BLUE
syvecs s6 plug and play £sold
ngk wide band lambda sensor £sold
04 plate uk sti semi closed deck avcs heads long engine very well looked after and serviced by its prevous owners we supplied this engine to previous owners last year hasn't done much work since still nice low mileage unit and in excellent working order ..no knocks rattles or oil or water use pulls very nice and runs faultless great replacement engine or wrx etc upgrade.sold as a long engine minus inlet/manifold/turbo etc £1350
jdm dccd 6 speed gearbox in excellent working order very very nice box very smooth in all gears no whines or crunches at all all works perfectly also as it should complete with matching r180 rear diff and matching gear selector mech and shorter 6 speed propshaft also great conversion package £2300
male ended heavy duty 114pcd sti front drive shafts excellent con £150set
r180 larger rear drive shafts excellent working order £180pair
114pcd wide track hubs in excellent working and good bearings £300set
6 speed starter motor £45
vf35 turbo charger £sold
blobeye front mounted intercooler kit £sold
sti large under tray good con £60
550cc pink injectors excellent working order great wrx upgrade £120set
Jdm sti water spray bottle with switch and jet in under bonnet mounted £60
uk sti red crinkle inlet tgv delete inlet good con complete with fuel rails great wrx upgrade £80
newage uk sti avcs engine wiring loom excellent con uncut or modded at all £60
full jdm sti dccd car wiring loom uncut or modded minus small engine loom £100
blitz stainless induction kit £sold
uk single scroll sti standard headers £sold
decatted 3inch down pipe £sold
power flow full custom 3 inch cat back system £sold
welbro 255 lph fuel pump £sold
perrin 3 port boost solenoid £sold
jdm rear lamba sensor excellent working order £40
metal header tank good con no leaks £25
air con pump excellent working order £25
air con condersor rad good con £25
top rad hose good con £10
bottom rad hose good con £5
washer bottle with pumps £15
alternator cover £10
battery claimp and threaded bars £10
WHEELS/BRAKES/SUSPENTION
wide track perrin red 25mm rear adjustable anti roll bar with bushes £sold
Ultralight 23mm front anti roll bar £sold
perrin solid stout mounts £sold
perrin alloy rear drop links £sold
jdm quick rack excellent £sold
jdm titanium strut brace rare genuine item £100
jdm rare added caster front alloy arms £sold
enkel 17inch 114pcd sti alloys all straight and true some minor curbing on 2 wheels nothing major at all tho all fitted with excellent kumho tyres all round which all have excellent tread levels £250set
gold brembo front brakes £sold
gold brembo rear brakes £sold
114pcd sti 50mm suspension set up £sold
front subframe £sold
front lower u brace good con and solid £45
rear subframe £sold
wide track alloy rear trailing arms £sold
pas steering pump in perfect working order £60
pas pipe with with remote bottle and cooler £30
114pcd space saver clears brembos etc good con £25
EXTERIOR BODY WORK
genuine jdm sti wide track bare shell complete with id and paper work some parts are left on like fuel tank and fuel lines all brake lines etc ideal projects etc £250
rare spec c roof vent £SOLD
spec c roof vent inner surround plastic and clips £sold
sti front bumper complete £sold
wide track rear bumper £sold
sti front grill with badge excellent con £45
blobeye alloy bonnet in good con with genuine scoop £sold
blobeye genuine HID jdm sti headlights £sold
blobeye tail lights £sold
blobeye sti wings £sold
sti twisted side skirts £sold
sti rear hi level spoiler £sold
sti boot lid good straight condition no marks or signs of rust showing (NO BOOT LOCK FITTED) £60
4x doors no internals or glass inc £30each
jdm power folding wing mirrors good con perfect working order £120pair
fuel filler door £15
front window good con £45
jdm factory tinted rear heated screen and rear side windows all in very good con £120set
jdm rear wiper mech in excellent working order £30
side mouldings trims £20pair
roof gutter trims £20pair
INTERIOR
kenwood double din dvd/cd/radio/sat nav/blue tooth etc head unit £sold
blitz 60mm pro gauges £sold
jdm defi style red dccd speedo dials simply stunning looks great on or off perfect upgrade for lesser newage models £180
jdm wide track centre console conversion kit£sold
wide track all black sti steering wheel in good con with air bag and clock spring for easy fitment £180
jdm sti seats £sold
jdm sti wide track sti door cards £sold
rare jdm sti wide track door switches with button for folding mirrors perfect working order £60set
dccd buttons £25each
sti blue carpet good con no rips etc great wrx upgrade £60
sti 6 speed red stitch gearknob £sold
newage dash top good con £30
boot carpet £25
boot side liners good con £sold
spare wooden wheel cover £20
Old 21 July 2014, 03:47 PM
ATWRX
ATWRX's Avatar
I'll have the Perrin Stout Mounts, PM paypal details
Old 21 July 2014, 06:31 PM
Pm sent thank you
All pm's replied
Old 21 July 2014, 08:41 PM
Blue by You
Blue by You's Avatar
Posted on 22b about the rear bumper Matty.
Sent you a PM as well mate.
Old 21 July 2014, 08:57 PM
Pics added and pm's replied
Old 21 July 2014, 09:09 PM
Blue by You
I'll take the rear bumper please Matty.
You have PM.
Old 21 July 2014, 09:49 PM
Ukshaun
Ukshaun's Avatar
Ill take the wings please Matt. Payment waiting
Old 22 July 2014, 01:45 PM
pm replied ukshaun thank you
all pm;s replied and sold items listed
Old 22 July 2014, 04:46 PM
Blue by You
Thanks for the bumper Matty, good to meet you today.
Old 23 July 2014, 08:29 AM
Thank you Steve nice to meet you also thank you again
All pm's replied
Old 23 July 2014, 10:52 AM
Fat Boy
Fat Boy's Avatar
I tried to call a couple of times, but voicemail left anyway.
Old 23 July 2014, 04:51 PM
all sorted john thank you again
all pm's replied
Old 24 July 2014, 02:35 AM
riiidaa
riiidaa's Avatar
payment sent for front bumper, bonnet, hid lamps, and skirts mate
(will need some front wings when you get another in)
Old 24 July 2014, 07:03 PM
Fat Boy
Fat Boy's Avatar
Thumbs up
all pm's replied
Cheers Matt,
j
Old 26 July 2014, 08:33 AM
Thank you both pm also replied
All pm's replied
Old 27 July 2014, 02:01 AM
95_s14
95_s14's Avatar
Nvm glws
Old 27 July 2014, 09:11 PM
No problem at all
All pm's replied and list updated all sold items listed
Old 28 July 2014, 01:47 PM
uk300 lee
uk300 lee's Avatar
how much for POD and 3 gauges? what make are they and which ones are they.
Many thanks Lee
Old 28 July 2014, 02:14 PM
they have already sold already
all pm's replied
Old 04 August 2014, 07:59 PM
list updated all sold items sold and pm's replied
61
11 January 2021 03:08 PM
ATWRX
88
01 February 2016 07:28 PM
Gooch89
11
30 December 2015 03:31 PM
Alex182
09 September 2015 09:32 AM
Quick Reply: RARE JDM STI WIDE TRACK BREAKING (dccd 6 speed/syvecs/brembos/jdm extra's/perrin)
