insanely stubborn suspension boltd
Hi ya'll.
Anyone got any tips on removing bolts behind the brake disc? I have managed to fit coilovers to one rear corner of my car. The other side is just too hard for me.
It is anti clockwise to unscrew isnt it? Not me going mad.
I dont have an air gun just a decent set of tools. Tried wd40 and other grease/rust removers, brut force, hammers even shouting at it. They just won't budge!
Lol shouting didnt work !! did you throw the F word at it ?
I hate these theres always one nuts etc ,,, i find shock and unlock type stuff much better then wd40 though for un seizing nuts etc ,,, six sided sockets are a must so they dont slip
I previously had a landy and they seem to suffer from a lot of seized nuts so i picked up a handy little butane blowtorch cheap off ebay that often allowed some pinpoint heat directed at the offending item which can free it up ,, ill try find a link
Edit - one of these i got as im scared of the damage i might do with a full size blowtorch but these get things well hot when needed as well as can solder with ithttp://www.ebay.co.uk/itm/IRODA-MICR...-/270955631270
Hex socket as above and if I remember correctly you have to lock up the nut with a spanner and actually unwind the bolt. A massive breaker bar was required for mine, although an air gun would be the ideal tool. Once your coilover is fitted you have to tighten the bolt again with the nut just locked in place with the spanner. This doesn't seem ideal but it does the job and mine haven't fallen off yet.
Ive heard of the blow torch trick. Thought about sitting there with a lighter under it!
Might ask a nearby garage if I can steal their air gun for a few minutes.
I managed the other one with a hex bar and a spanner and lots of f'ing and blinding.
1 Post
Not sure about "other grease/rust removers" but WD40 is worthless for undoing stuff.
I struggled with the same bolts on my car, NOTHING budged them and the motor in my mains powered rattlegun started smelling a bit ugly!
I then went to a motorfactors and got "Plus Gas" and it unseized them within about 20mins.
I used a 3.5ft breaker bar on a 6 point socket and had the bar so bent with force that I thought it was going to snap before the bolt finally broke loose! Go for loosening the nut first rather than the bolt too, it's usually easier to free them off that way first.
Proper penetrating oil is a must, forget WD40. Small wire brush give the threads a good scrub and spray liberally, then walk away for an hour or two. Ideally I always do this the day before and usually twice before I even get involved with trying to undo rusted bolts.
if its the 2 big fixing bolts you would be better undoing the nut, if your trying to undo the bolt you are trying to undo it and all the rust that`s holding it in place,
the nut will come off with less torque required,
I use a socket with T bar then use the trolley jack to undo it, worked on dozens of cars for decades until I got an electric impact gun lol
Well I used some loosening stuff let that settle for a bit and borrowed a 28" breaker bar from a nearby racing team (recently discovered), started with the nut and eventually did it, but **** me was it had work.
Feel like I've played rugby (which I do).
Rear coilovers on, fronts tomorrow. Did a 30mm drop at the rear. See how the splitter fares with a 30mm drop at the front. No camber and set to soft for a more comfortable ride (one hopes).
Cheers for all the help!
Tried the muscle route, alas I am not strong enough! Blistered hands though
Driftworks.com were good to me. Not only did they throw in some degreaser with my coilovers but they gave me a free wham bar! (Not to be used ad a breaker bar). Didn't know they still made those.
Anyway white lithium grease is doing its over night.
As a noob attempting my first coilover install I can safely say it is simple to do just requires patience and strength and I'm very impressed with the build quality and ease of adjustment of the coilovers. Lets hope they ride well.
Take it to your local garage and ask them to get the impact gun on it for you - problem with spanners and sockets is that if they slip and round off the corners your screwed. They should only charge you a few quid if you know them well enough. Oxy is more fun though!
Clean the thread and run a nut up it the right size cleans the thread up perfect.Give the hex head of the bolt a few cracks with a hammer or punch and hammer if you can get near with hammer .Use the hammer and punch on the hex faces of nut as well
