Scooby 921 spacers for strut change
I found these a while back in my bits and now realise what their for (forgot I had bought 2 sets)
I imported them from the states at a silly price delivered.
They are basically washers/spacers that sit on the shoulder of the strut for rears if you are putting 2003-04 struts onto a 2004-07 car.
The fronts go on fine but the rears have a slight gap where you WILL get knocking and clunking if you have done the swap.
Here's a link to the exact place I got them from http://www.fastwrx.com/products/tic-...-strut-spacers
Can add photo but it's only 2 special washer/spacers designed for this upgrade.
£15 delivered for the pair.
Hi Mate
would these work the same on my bugeye, i have put on blobeye coilovers and get a clunking noise, so if these would work ill have them
Did you fit them yourself? And did you notice a space where it's not seated correctly on the top mount to shock?
I had them as I got some bugeye jdm shocks and put them on a 55 plate blob if that helps.
I'll try find some pics for you to see difference.
Bit of info here, see 2nd picture where the strut has a shoulder which the 921 spacer cures for the top mount to sit correctly.
http://forums.nasioc.com/forums/showthread.php?t=563382
im as bad as you just re-read again, im gonna need new topmounts not the spacers arent i?
dont know if i can get them, i do have the website where they were originally purchased from but as there second hand it might be easier to just put my normal suspension on and get some coilovers made for the car
thanks
thanks
