New Godspeed Brakes group buy
Old 15 July 2008, 02:30 PM
Godspeed Brakes
THE braking specialist
Godspeed Brakes's Avatar
Default New Godspeed Brakes group buy
Following on from the popular group buy I ran in May , I am offering similar deals for the next month , the pads have gone up slightly as I have had increases on the 1st July.
I can supply discs for any Impreza or Legacy , if your model isn't on the following list please ask.
All our discs come grooved as standard , I will only offer drilled discs as well if you want it for show more than go ! The pads available today can generate so much more heat that drilled discs can end up cracking around the holes , all makes of discs that have been drilled will be prone to this. The thicker the disc the less chance of this happening , moreso on the standard sized discs.
All my discs come with a 12 month guarantee against warping , if its down to faulty discs they would be changed for another pair , but if its down to incorrect fitment , or sticky calipers , then they would not be covered.
I am seeing a lot of Subaru calipers now for reconditioning , so care must be taken when fitting new discs to make sure all pistons are free to move , if not , I can supply any parts needed to put them right , from a bleed nipple , to new seals and stainless steel pistons that dont rust , to fully reconditioned calipers.
Just about all parts are available for next day delivery , somedays I am pushed to send out all orders so would go within 2 days.
If you have any questions please call me on 01656 723060 or email me on ian@godspeedbrakes.co.uk.
Grooved Discs and pad prices.
Classic model
294mm fronts to fit the subaru 4 pots = £89 a pair
266mm rears to fit the 1 pot sliding calipers = £89 a pair
290mm bugeye discs for the 2 pot conversion = £115 a pair
290mm bugeye discs and our rear fitting kit = £150
Type R rear vented discs - 290mm with a 190mm handbrake drum = £130 a
pair
Fitting kit to fit the subaru 2 pot calipers = £49
Fitting kit and handbrake shoes to fit the Brembo 2 pots = £175
Pads per axle set
Ferodo DS2500's £125 a set
2001 onwards WRX
294mm fronts = £89 a pair
290mm rears = £109 a pair
Pads per axle set
2001 onwards STi
326mm fronts for the Brembo calipers = £150 a pair
316mm rears for 2 pot brembo calipers = £170 a pair
Our 326mm 2 piece discs and bells £325 a pair
these are available in 5 x 100 and 5 x 114 PCD
Pads per axle set
Ferodo DS2500's £140 a set
Godspeed 335mm kit for the Subaru 4 pot calipers , as long as you dont have any sticky pistons in your calipers , this kit is a match for anything the same size , it totally transforms the performance of the standard calipers
Complete 335mm kit with 335mm x 32mm grooved discs and bells , calipers spacer kit , steel mounting bracket kit , Ferodo or Mintex pads ( this kit uses larger than standard pads )
Group buy price £550
replacement 335mm x 32mm discs £275 a pair
Reconditioned Subaru 4 pot calipers
We completely strip the calipers , bead blast them , prime and spray them any colour you want , and fit new stainless steel pistons , new seals and bleed nipples .
These are better than new when finished
£195 a pair exchange
330mm x 28mm discs and bells to fit the Prodrive Alcon calipers , I can supply these for £375 a pair
330mm x 28mm or 304mm x 28mm discs to replace AP discs £275 a pair
There will be no list to make of who wants what ,, just contact me and order them
Cheers Ian
01656 723060
Old 15 July 2008, 03:03 PM
RA Dunk
RA Dunk's Avatar
any more info about the ones i have from the AP kit? is it the 325 or the 330 ML discs i need? i need em bloody quick like
Old 15 July 2008, 05:57 PM
Godspeed Brakes
HI
You have the CP5200 calipers , which take a 28mm thick disc , I can supply you 325mm or 330mm to fit your bells , the 330mm discs will have 2.5mm spacers to fit between the calipers and brackets.
Can do them for the same cost as the 335mm ones in the group buy , £270
Cheers Ian
Old 15 July 2008, 07:09 PM
WUZ
WUZ's Avatar
Ian - are you still taking cheque only or are you able to do cards now?
Russell
Old 15 July 2008, 07:29 PM
Godspeed Brakes
Payment can be made via paypal , cheques or bank transfer
Cheers Ian
Old 15 July 2008, 07:34 PM
RA Dunk
RA Dunk's Avatar
perfect!! if i pay now how soon can you get them to me?? got a trackday this weekend i was hoping to get to, do i send the money via pay pal to this account ian@godspeedbrakes.co.uk or do you have a seperate one?
Old 15 July 2008, 07:50 PM
Godspeed Brakes
Acid
I can get a pair to you on friday morning , but you would have to bed them in for at least 300 miles of A & B roads before going on the track.
Yes use my email address as recipient for paypal payments.
P&P is £15 , send me an email with your full delivery details and what you want
Cheers Ian
Old 15 July 2008, 08:40 PM
RA Dunk
RA Dunk's Avatar
hi again payment has just been sent
Old 16 July 2008, 11:33 AM
New_scooby_04
Moderator
New_scooby_04's Avatar
Location: The Terry Crews of moderation. P P P P P P POWER!!
Any chance of including the AP kits in the GB Ian? Or even just the calipers from the 308mm kit?
Regards,
Ns04
Old 16 July 2008, 11:37 AM
SamUK
SamUK's Avatar
Ian, Thanks for the reply in the other thread....
Okay can i get maybe drilled or grooved discs...? which one produce the least amount of noise when breaking?
--Sam
ps: if i wanted to go for bidder discs, am i looking at a new brake kit? (MY03 STI)
Out of intrest how much are the 6pot Ap's for the groupby...my brother has them on his M5..and there just awsome!!!...
Old 16 July 2008, 01:15 PM
scoobboy
scoobboy's Avatar
Hi,
Can you give me the price of pads for the AP 6 pot 330mm setup?
I want the following discs too, so if you could give the price for everything that would be great.
330mm x 28mm discs to replace AP discs £270 a pair
Old 16 July 2008, 03:33 PM
Guv
Guv's Avatar
Hi Ian
Can you do a set of front disc's for spec C, if so which ones are they and hows much...Cheers..
Guv
Old 16 July 2008, 07:51 PM
Godspeed Brakes
Originally Posted by Guv 'Spec C' Dhillon
Hi Ian
Guv
any of these for the Spec C
2001 onwards STi
326mm fronts for the Brembo calipers = £145 a pair
316mm rears for 2 pot brembo calipers = £165 a pair
Our 326mm 2 piece discs and bells £295 a pair
Pads per axle set
Mintex Extreme £69 a set
Ferodo DS2500's £135 a set
Cheers Ian
Old 16 July 2008, 07:55 PM
Jam Performance
Jam Performance's Avatar
Default Ds2500
Ian,
Had some Ds2500 pads off you last lonth for my 335mm Godpseed conversion, im finding the pads very dusty - its wrecking my advan wheels! Do you keep any other pad with similar stopping ability but less dust
Old 16 July 2008, 07:57 PM
Godspeed Brakes
I have been doing some good deals on the AP caliper kits , I cant offer any better ones , I can supply the 335mm kit with AP 6 pots for £1200 complete.
Scoobboy
The Ferodo DS2500 pads for the AP 6 pots to fit the 330mm discs are about £175 , I'll sort you out an exact price in the morning
Cheers Ian
Old 16 July 2008, 08:02 PM
Godspeed Brakes
Originally Posted by K18LLR
Ian,
Unfortunately all pads will give off dust , the performance pads will give off a harsher dust , I dont find the Ferodo's are hard on the wheels , maybe try the wax stuff on your wheels to see if that makes it easier to clean them
Cheers Ian
Old 16 July 2008, 08:11 PM
scoobboy
scoobboy's Avatar
ok mate
Old 16 July 2008, 09:29 PM
internethoudini
internethoudini's Avatar
I have had a set of 4 pots refurbed by Ian and i have to say what an absolute top job they were as well. Definitely recommended! so much so....
Any chance of a price on the refurb of 2 pot rears?
Old 16 July 2008, 09:33 PM
bulletproofbob
bulletproofbob's Avatar
already ordered and in the post!! nice one ian!!!
Old 16 July 2008, 10:29 PM
New_scooby_04
Moderator
Ian,
how about the AP 4 pot 308mm kit or calipers?
Regards,
Ns04
Scoobboy
Cheers Ian
Old 16 July 2008, 10:35 PM
Granby
Granby's Avatar
Ian,
I've always found DS2500's to be quite dusty for the first few weeks but once they have bedded in they aren't so bad, i wax (the wheels that is) and it makes them a lot easier to clean
Old 16 July 2008, 11:03 PM
RA Dunk
RA Dunk's Avatar
Ian,
i killed the front wheels on my UK turbo using wonder wheels trying to get that bloody dust off, stuff seemed to weld its self the the alloy
Old 16 July 2008, 11:12 PM
Granby
Granby's Avatar
I use poorboys wheel sealant and then clean with mequiars hot rims all wheel cleaner
Think wonder wheels is a acid based cleaner so not very good for the wheels
Old 17 July 2008, 09:51 AM
RA Dunk
RA Dunk's Avatar
yup totally agree, thing is with the DS2500`s nothing else seemed to remove the dust, just ordered some poor boys wheels sealer though
Old 17 July 2008, 03:45 PM
Godspeed Brakes
Acid
Your discs were done today and sent out as planned , will be with you tomorrow , dont forget to put some miles on them before your trackday
Cheers Ian
Old 18 July 2008, 11:29 AM
RA Dunk
RA Dunk's Avatar
Acid
Cheers Ian
yup, no worries, cheers , im not going to make that trackday now anyway by the look of things
Old 18 July 2008, 04:45 PM
RA Dunk
RA Dunk's Avatar
ok the discs arrived today, thanks alot Ian
Old 20 July 2008, 01:01 PM
Rich_B
Rich_B's Avatar
Originally Posted by New_scooby_04
Ian,
Regards,
Ns04
Hi Ian,
I'd also be interested in what your current deal on the AP 308mm kit is.
Cheers,
Rich.
Old 20 July 2008, 07:51 PM
yellow sti6
yellow sti6's Avatar
£175 a pair exchange
Hi ian
Are these posted in the price above ??
and what colours can you do ??
plus do i keep the old pins etc or do you get new ones ??
cheers craig..
Old 20 July 2008, 08:23 PM
Godspeed Brakes
Originally Posted by Rich_B
Hi Ian,
Cheers,
Rich.
I'll sort a price out tomorrow for you
Cheers Ian
Quick Reply: New Godspeed Brakes group buy
