ver1/4 440inj/type ra gearbox setup/inlet/lambe/xbox games and many others
550cc nismo ver1/4 injectors/type ra gearbox setup/asnew radiator/xbox games &others
due too change ov plans i have few items up for grab all items in mint working order and can send more pics if requested can post most items or collection preffered
nismo 550cc injectors in mint work order same as sold by flat for on line for 520+vat..very little use comes with matching wiring clips price dropped too 180
asnew classic rad used for less than 50miles in mint con comes with 1fan still attached please note pipes are not included £35collection only please
complete ver1 type ra gearbox setup gearbox code ty752vb3ba mint con no whines rattles grinding done approx 70.00miles all perfect gear changes also..this is a very close ratio box and is ideal for hill climbs or sprints or a very quick street car only changing due too big power plans comes complete with box,linkages,prop,diff and all shafts all in mint con £380 for box pm me if interested in diff and shafts also...GEARBOX IS NOW REMOVED AND READY TOO GO WILL POST PICS ASAP
alternator in mint working order came off ver3/4 low milage sti £15
std flywheel off low milage ver 3/4 sti in good con no wear on plate £20
std clutch from low milage ver3/4 sti perfecly useable still plenty life in taken off too upgrade comes complete £20 or will do for £30 with fly wheel
ver 3/4 coil pack in good working order no cracks and connector in good order £20
air con pump good working order £10
have few xbox 360 games no longer used all in good working order
need for speed undercover £15
call ov duty 4 modern warfare £10
test drive unlimted £10
forza motorsport 2 platinum £10
all boxed with instructions
any questions about any items please ask and il do my best to answer if more pics or info needed also just ask and il do my best collection is preffered from post code ws2 which is walsall 2mins from junction 10 ov the m6 motorway
call tx or pm cheers07785942237
wazo pm.d back bud ,matrix im not planning on going jap feast as planned a wk end away sorry im about half hour away from stripping manifold and re paintingit in crackle red too sell for abit more hopefully??its fairly heavy as u can imagine and only way i have ov sending is bye royal mail so posteage would be around 18/19quid or u could arrange ur own collection or collect in person bud
hi bud i just ben to weigh the inlet and tipically the scales dont work they the electronic type i thought battery had gone but its fine il try get hold ov some others now im back but guess the weight too be around 8kg
hi bud box i have is 27"l x 17"w x 10"h
maniflod is slighty smaller but best box i couls find this inlet is complet so has throttle body/fuel rails/lines/idle valve/inlet pipe still connected so is heavyer than a stripped 1 remember did u want injectors also or just maniold minus injectors??
no probs matrix il pm u bit later on regards too ur pm bud cheers...
grizz flywheel is std size so take its 225mm but can measure if u tell me what part u want meassuring bud.im not going jap feast or silverstones as plans have already been made sorry.postage will be high due too the weight as u can imagine and i only get too use royal mail so might be worth looking into sorting or collection out and il wrap it up no probs for u???
