hi mate, what power are these good for on a classic? with everything provided it'll fit straight onto a version 5 classic sti? how much better are these over the standard version 5/6 ic?
ive got an sti-8 ic which i plan on selling due it being too much work to fit, heard these are a lot easier to fit.. let me know, very itnerested.
1) As far as I`m aware, these are good for upto 400bhp but you would have to check that.
2) All you need to do is make a bracket for the L/H side of the TMIC, apart from that it will fit without any more mods. Take a look in the technical guides section as there`s a `how to' in there.
3) This TMIC is bigger than the classic TMIC`s so better/more airflow.
4) The major mod has already been done, ie. removing old D/V location and welding a new D/V connection on the corner. All that`s needed is a bracket to connect between the LH hole on the TMIC and the bracket that`s mounted to the engine block.
Hope this helps, not very technical when it comes to scoobs.
