Private For Sale - Car Parts & Accessories Only ScoobyNet Plus members and For Sale forum subscribers can post new threads in this forum. Click here for details.
Bailey Atmos Dump Valve Newage
Old 08 July 2009, 10:23 PM
DeanF
DeanF's Avatar
Default Bailey Atmos Dump Valve Newage
Removed from my 53 Plate Blobeye & Refurbed with a new seal & bore polish.
Works like a new one for a fraction of the cost
£35 Inc postage
Bung for the Recirc pipe included.
Cheers.
Dean
DeanF is offline
Old 13 July 2009, 09:12 AM
DeanF
DeanF's Avatar
Sold to S55 CBY
Thanks.
Dean
DeanF is offline
Old 14 July 2009, 02:58 PM
scooby_me
scooby_me's Avatar
sorry to hijack,
i have the same valve, and idea how to adjust it?
Daz
scooby_me is offline
Old 14 July 2009, 09:21 PM
DeanF
DeanF's Avatar
Originally Posted by scooby_me
sorry to hijack,
Daz
No problem.
You can't adjust them as such, All you can do is fit a stiffer/softer spring, To make them Hold/release boost, Sooner/later Etc
Dean
DeanF is offline
Old 14 July 2009, 09:26 PM
scooby_me
scooby_me's Avatar
Thanks, i was confused!
I read this...
Modify Your Bailey BOV
Found on the web somewhere....
With the kit fitted and all not working you will experince to common problems:
1- Dump Valve is working but does not idle (stalls at junctions etc...)
This is due to the dump valve opening when the engine is at idle or on deceleration. The engine then draws a small amount of air through the valve thus by-passing the meter unit causing the car to stall.
To fix remove the grey fitting on top of the dump valve (I used a bicycle tool bar the one with hex shapes as on e size fitted perfectly) and then insert a philips screw driver until you feel it fitting into a screw. Now with all in position use your finger to jam in one of the holes so only the screw moves and not the dump valve (If you see the black area in the hole turn you are not adjusting the valve) now turn 1/8th turn anti-clockwise and refit the plastic (grey) clip to top of valve and refit vacuum hose and try again if same problem repeat until all is fime. (remeber to jam the black area through the hole when adjusting otherwise you are doing nothing!!!)
2- Car runs fine but Dump Valve is not Dumping!!!
This is caused by the engine not creating enough vacuum to open the valve. Remove to grey fitting from the top of the dump valve and and insert screw driver (philips) as above and this time turn clockwise 1/8th turn. Remeber to jam finger so no movment is seen through hole or you are not adjusting the valve just turning everything inside.
If you hear a creaking style noise when you turn the screw you have not jamed the valve and are not therefor adjusting the valve.
If the problems above continue the repeat each process until all works well!!!
But when i unscrewed the nipple it didnt seem to have anything to adjust!.
Does yours actuall make a ppppsssssssssssssssss noise when you change gear?
Daz
Old 14 July 2009, 09:46 PM
DeanF
DeanF's Avatar
I read this...
Daz
Yes, makes a Phsshh & no stalling Etc, Well did do, as i now have standard one back on, Bit old for Dumpers Now .
As you say, Once the Hose tail is removed, There is nothing to adjust, The Pistons are on a fixed length rod & can operate independantly, One on Vacuum & other on Boost Etc, Two springs, One for each piston (As Such). If you push the Rod in at the Bottom with your finger/thumb does it push in & snap back closed once released ?? It should do..
Bailey will service them for you, with quite a quick turn around, & will fit a harder spring for higher boost applications.
Bailey Motorsport
Dean
DeanF is offline
Old 14 July 2009, 09:49 PM
scooby_me
scooby_me's Avatar
dont suppose you still have yours? i`m looking to buy one just to test it!
Old 14 July 2009, 10:08 PM
DeanF
DeanF's Avatar
Sorry, Posted the other day.
Im sure if you put a request on here, Some kind person near to you will do a temporary swap for a few beer tokens .
1st thing, Un-bolt it & try the thumb test, 5 Mins out of your time.
Dean
DeanF is offline
shorty87
19
22 December 2015 11:59 AM
sedge69
Wanted
01 October 2015 09:44 PM
buckerz69
29 September 2015 04:16 PM
speedrick
28 September 2015 01:06 PM
Quick Reply: Bailey Atmos Dump Valve Newage
