Essex Subaru Owners Club The official dedicated forum for Essex Subaru Owners Club Events.
Exhaust swap??
Old 21 July 2009, 08:36 PM
Cornelius
Cornelius's Avatar
Default Exhaust swap??
Does anyone want to swap my extra quiet stainless steel 3" system for their noisy bugger one?
Funds are a little tight at the mo as my new job is paid monthly where as the old job was weekly, so can't really afford to have the silencers cut out just yet!
Old 21 July 2009, 10:16 PM
scooby seb
scooby seb's Avatar
i've got some 3 inch stainless at work mate if you want to drop the exhaust section down we will chop it out and stich in the new bit
Old 21 July 2009, 10:21 PM
e6graham
e6graham's Avatar
cornelius your exhaust is a one off its been made for the car i was going to swop it with jj some time ago but it dont fit any other car so good luck with that one lol
Old 21 July 2009, 10:36 PM
Cornelius
Cornelius's Avatar
JJ said, but it's joined onto a standard catted downpipe which baffles me if you excue the pun
Old 21 July 2009, 10:38 PM
V4JDMSTi
V4JDMSTi's Avatar
how can it only fit one car? surely it'd fit any classic?
Old 21 July 2009, 10:39 PM
Cornelius
Cornelius's Avatar
By the looks of it, I may have to hold you to that mate!!
Old 21 July 2009, 10:41 PM
Cornelius
Cornelius's Avatar
JJ said that one of the guys at Mr Clutch wanted the exhaust, but it wouldn't fit on his car.
Just found out it waw e6graham.
Am totally confused
Old 21 July 2009, 10:48 PM
e6graham
e6graham's Avatar
it was me and it dont fit as i said good luck never seen anything like it its like a one off as i said !
V4JDMSTi
V4JDMSTi's Avatar
That's bizzare. I want to see how it's different now
Old 21 July 2009, 10:49 PM
53's Avatar
Insulating tape !!! why do you think it's so quiet ?!
Old 21 July 2009, 10:51 PM
V4JDMSTi
V4JDMSTi's Avatar
e6graham
e6graham's Avatar
its pants and insulating tape is the only way lol
Old 21 July 2009, 10:52 PM
Cornelius
Cornelius's Avatar
could you clarify why it don't fit please?
I'm not doubting you at all, I'm just totally perplexed, JJ also said a decat downpipe won't fit either, so now want to get to the bottom of it
Old 21 July 2009, 10:57 PM
e6graham
e6graham's Avatar
im not really sure mate but total dif from normal classic fittment i wanted it as its 7mm thick and thought it was the dogs boll*x of an exhaust it looks like it cost a lot of doe but it dont fit mine which is a normal classic fittment and dont fit pauls which is normal classic fittment and just looks to me like its a one off made for the car anyway im not sure and wouldnt like to say but its not a normal classic exhaust.........
Old 21 July 2009, 11:06 PM
Cornelius
Cornelius's Avatar
7mm thick??? it's not an exhaust, it's an RSJ with baffles!!! lol
Thanks mate
Scooby Seb - looks like I'll be calling on your services in the near future mate
Old 21 July 2009, 11:08 PM
e6graham
e6graham's Avatar
its as thick as fu*k it must of cost £1000 at least
Old 22 July 2009, 10:56 AM
Mark_B4
Mark_B4's Avatar
Location: Basildon, Essex Scoobyless Crew - MX5 Division
I suppose if it was bought as a turbo back system, the downpipe could be non standard, which would cause the fitment issues
Old 22 July 2009, 12:06 PM
Cornelius
Cornelius's Avatar
it looks like a standard catted downpipe mate, hence the confusion
Old 22 July 2009, 08:25 PM
WRX_Dazza
WRX_Dazza's Avatar
Location: Going further than the station and back !!! ZZZZZZZZZzzzzzzzzzzzz
it has a flange (no giggling) type fitment to centre section, as opposed to the H&S type flat joint (std aftermarket type), so a centre section to match would be required.
i think thats right, from what i've seen and had explained
hth
dazmondo (zorst guru, clutch guru, spark plug guru - self-appointed)
Old 22 July 2009, 08:33 PM
e6tony
e6tony's Avatar
hth
Well done dazza,i am impressed and therefore hereby appoint you zorst guru,clutch guru,spark plug guru
glad you was listening
Old 22 July 2009, 08:35 PM
WRX_Dazza
WRX_Dazza's Avatar
i try my best mate..... if you get any probs with rattly golfs, give me a shout i know what to look for now - and thanks for the free training.
Old 22 July 2009, 08:37 PM
e6tony
e6tony's Avatar
no probs mate,maybe you could help cornelius wiv his zorst now mr guru
Old 22 July 2009, 09:50 PM
scooby seb
scooby seb's Avatar
just give us a shout mate, let us know how long the box is that you want cutting out and i'll makesure i've got enough pipe,no biggy if not as burton sells lengths of it
Old 22 July 2009, 10:20 PM
Cornelius
Cornelius's Avatar
hth
OK Mr Guru
As mentioned, the downpipe is a bog standard subaru catted one.
If Hayward and Scott centre sections fit a standard catted downpipe, why can't this exhaust go on any other Impreza?
Admittedly I've only had a quick look uder the car and it looks like a standard flanged fitment as you's expect to see on a H&S, so at the moment, I can't see what the problem is!
Only way to settle this once and for all it to take the exhaust off and try it with the bog standard catted down pipe I've got in the garage which is from the old Scoob.
Old 22 July 2009, 10:25 PM
53
53's Avatar
Just drill a hole in it, old skool !
Old 22 July 2009, 11:00 PM
V4JDMSTi
V4JDMSTi's Avatar
i know someone that will be after a nice stealthy exhaust soon
Old 22 July 2009, 11:15 PM
Cornelius
Cornelius's Avatar
My Scoob has got Flat Eric well and truely pipped stealth wise on the noise front!! The poxy thing is quieter than ME!!!
Old 23 July 2009, 12:15 AM
ScatRat
ScatRat's Avatar
Sorst report £1295 actually was a one off for that car, tried several cars to put it on none fitted, I think i said before, If you de cat it corn take it easy mate, and get mapped straight away,
i told you why the thickness etc i think , the down pipe or upipe was a ceramic one which got damaged 4 years ago on a broken drain, i beleive the turbo housing is all different too, ill give you some spec later ill pop rond for a tea, i did take to a garage who said bring it down ill put some 3" piping on it, and then when i got there they said not touching it, lol,
I think its to do with the back pressure or something, i asked em to cut away the bafflers," said NO,
Dont make sense....
anyway ill pop round
JJ
Old 23 July 2009, 08:06 AM
Cornelius
Cornelius's Avatar
Thanks JJ, you're more than welcome to come round for a tea!
I don't really want to have the zorst chopped up and welded as you know it's nicely made, but it's too quiet for me!
Old 23 July 2009, 08:32 AM
mr_D
mr_D's Avatar
cut it up. lol you know you want to
Quick Reply: Exhaust swap??
