do you know if this will fit a pre facelift bonnet and i just need to change the headlights?
cheers
neill.
It fits but it makes the bonnet release tight to get to - you'll learn the hard way how to get to it without loosing too much skin from your knuckles….
I had to remove the rubber lining from the front of the underside of the bonnet to make it easier to close the bonnet without having to slam it hard…
