Carl Davey header tank insulators
Brand new unused,they should fit all age Impreza's.
Taken from Carl Davey website;
These remote-mount header tank insulators offer the best form of insulating the inlet manifold from the coolant header tank short of completely relocating the tank. Very easy to fit, you can be enjoying their benefit in minutes.
The 9mm thick spacers are manufactured from Glass-Filled Nylon 66, a material that has a very low heat transfer coefficient. Fitting these spacers between the coolant header tank and inlet manifold of your Impreza is a great way of reducing heat transfer from the tank to the manifold. This helps reduce charge temperatures which increases the density of the air improving engine performance.
The spacers are CNC machined and incorporate brass inserts to facilitate secure fitting. Countersunk stainless steel bolts are also included to ensure a neat flush fit. I highly recommend fitting these in conjunction with a pair of Insulating Inlet Manifold Spacers.
What's Inside
The kit comes complete with:
* 2x Head Tank Insulators
* 2x Brass Inserts (fitted)
* 2x Stainless Steel Countersunk Bolts
* Illustrated Fitting Instructions
£10 delivered.
What's Inside
£10 delivered.
Location: South Wales - Stuck on this rollercoaster, get me off!!
What's Inside
£10 delivered.
What's Inside
£10 delivered.
Sold!, PM me your e-mail addy and I will pay through paypal if ok?
Si
