apexi N1 coilovers £200 CHEAP!!!
have some apexi N1 coilovers brought them but cannot adjust the ride height for anything.(except drivers side) all locking collars are free to move and adjust for rebound and preload...
these are definatly track orintated coilovers has too harsh on the road but unbeliveable on track.
come with pillow ball top mounts in excellent condition and one tein C spanner
you can see how rusty they were to how much cleaning ive tried to give them to free them up. theres only three shown has drivers one is fine
there currently with someone who can rebuild coilovers who will do these for between £200-£250 again will put you in touch but payment for coilovers will need to be settled
from apexi
Apexi N1 Damper Systems provide awesome driver feedback and response, as well as a high level of tuning flexibility. Born from the grueling N-1 Endurance Race Series, the Apexi N-1 Dampers feature adjustable spring perches and adjustable lower collars so that ride height can be changed without affecting the length of the damper stroke. The shock absorber is a gas-charged, short-case, short-stroke, monotube design that can be fine-tuned with its 13-step ride adjustment settings. With the proper equipment and technical knowledge, the dampers can be disassembled, revalved and rebuilt to suit the requirements of hardcore suspension gurus. The Apexi N1 Damper system also includes high-performance upper pillow mounts (unless indicated otherwise) to complete this comprehensive damper system. Apexi N-1 Damper Systems use the highest quality materials and are manufactured in-house at our Fuji, Japan factory to tightly monitor quality control and ensure years of reliable service.
from apexi
eversham located in birmingham can post for extra £20
@parrg341 the hub mount part is what adjust not the spring platforms for ride height and its just stuck solid for some reason
all four there
all four there
