** SWISS' UK SCOOB BEING BROKE **
** SWISS' UK SCOOB BEING BROKE -NOW WITH NEW ITEMS and PHOTOS **
NOW ALL PRICES DROPPED
Parts still for sale
Alternator £35
Fitted about 18 months ago so in pretty good nick
Halfords battery with lifetime guarantee £15
(though that could mean anything )
Fitted about 12 months ago
Shark fin trims £35
These are in perfect condition and an ideal way to spruce up those tired and mottled items that you get on classics. Bloody hard to find as well
Steering wheel UK Momo £30
In pretty good condition, a bit of wear on the top of the wheel average with the year of the car. Complete with airbag and wiring and the horn works
May include finger marks where I have gripped it hard when on track
Scoobyworld Boot Mat £45
A lovely mat tailored for the classics in royal blue with dark blue edging.
Mine does not have the STI logo but it is a great way to smarten up the boot
Under dash facia £10
Heater vents and top bin £10
Comes with the top cover as well
RAGE Extreme Positive Charge System £15
Performance ground wire kit which will make the electrics of your Impreza work more efficiently.
Other benefits can be easier starting, improved throttle response and longer lasting battery charge.
This has never been fitted, still in the box
Centre console trim section, all in good nick £5
A chance to handle swiss's **** £20
Boost solenoid £35
AP Racing Exedy Clutch rated to 400BHP + £100
Entire dash - a perfect item if you are looking to do a bit of flocking or just need a replacement £35
*note the air bag will be removed *
White faced UK speedo dial set £35
*around £78k on the clock *
Flywheel UK - £40
This was from an STI3 and meant to be lightened and balanced but on inspection it looks only to be balanced
Glovebox - £20
I have removed the sweets, parking tickets and assorted selection of pens that dont work
Radiator - £50
In perfect condition
Seatbelt trim (A pair) - £5
Starter motor - £10
Steering cowling trim - [B]£5
These parts are also available
- 1 Clutch slave cyclinder 10
- 1 Brake master cyclinder 10
- 1 Cam sensor 10
- 1 Crank sensor 10
- 1 Coolant temp sensor 10
- 1 knock sensor 20
- 1 Brake servo 15
- 1 Header tank 40
- 1 Exhaust manifold 25
- 1 Injectors 440 90
- 1 Coilpack 35
- 1 Turbo inlet pipe 35
- 1 MAF 50
- 1 Fuel rails 20
- 1 Boost control solonoid 35
- 1 Map sensor 30
- 1 ABS pump 50
Drivetrain
- 1 Rear diff 3.54 UK 80
- 1 Propshaft 20
- 4 Drive shafts UK 140
- 1 5 speed UK gearbox 250
Exhaust
- 1 Scoobysport centre section 70
Moderator
You have some serious work to do in the following weeks to come then Chris.
Still possibly interested in the door cards here complete with all the trim parts.... a set have come up locally which I am waiting to hear about but would be interested to see what yours are like also.
Instructing with fear
1 Post
when we had that chat on the phone i also said about the suspension and whiteline bits lol and i also wanted that bonnet scoop and front bumper as for the gearbox and flywheel- i had a new clutch fitted and it cured the problem so i wont be needing them now- sorry mate.
Also what are your speedo dials like?
The bumper and splitter is promised to Steve Whitehorn
The suspension lot are reserved
Bonnet scoop is yours
Speedo dials are in top nick ...dont forget that on these cars the speedo reads what you get on the clocks...so I think mine reads about 72K
I take it you need the handle plastic bits as well
All fixings will be included as well
